Just Fishing's 09 Tahoe Build thread
I always wanted to see what these looked like inside, so i took apart my old ac compressor.
each piston is like a lesbians best friend, double sided.
so 10 cylinders technically.
I also confirmed that all of the oil has been removed and measured by doing this.
:cheers:
Going through it real quick, it looks in good condition.
the clutch looked like ass, i don't think it had much left.
Reason for changing this was for mileage, and the weird high pitched squealing i heard when it was running.
Am I the only one that wants to see one of these in an engine form, like maybe a 2-stroke?
Just Fishing
Just Fishing
Can't fix stupid
Utah
I thought about it for a sec.
Impossible with this design, but i think you could make a mean tire inflator!
Issue is that the pistons cycle by a sorta flat disk that's got some wavy action.
The action of that wave is in the center of the lesy double piston setup causing them to work the lesy holes with some double pumping action.
I feel like i could make that dirtier sounding if i put in some effort.
:D
Just Fishing
Just Fishing
Can't fix stupid
Utah
machine shop called today!
looks like they bumped me to the front of the line.
got my stuff back, but i have a little concern.
first they should need to add weight to the crank to counter the extra weight of the pistons right?
It looks like they removed weight...
I took my wife's food scale and measured the pistons with rings, wrist pin, etc.
then took the oem with the same stuff.
sure enough, the new stiff is heavier...
Next the crank work, googling around it looks like the stock specs are
Main: 2.559
Measured: 2.556
Rod: 2.100 in.
Measured: 2.097
So i'm looking at some undersized bearings to make up for the difference.
found some nice .001 undersized for the mains
gets me closer...
then for the rods, i found some .001 and .002 undersized.
but they appear to come in singles, so i figure i might as well order one of each to see where it lands then order the rest.
:D
Indeed. It's like a circle jerk and ******** combined. A "circle bang", if you will.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Order placed, now more waiting!
Decided to go with the "Clevite H" bearings...
As for the assembly balance, I'm going to assume it's gtg.
so I'll run it as is.
they did mention that they would remove material from the pistons, and rods in order to achieve the balance.
I see material removed from the pistons, and i assume the remaining was probably the crank polishing...
Just Fishing
Just Fishing
Can't fix stupid
Utah
crazy, i can't imagine that it would have worked with this style.
Just Fishing
Just Fishing
Can't fix stupid
Utah
I was going through my parts once more, and noticed they included the weight card for the engine balance!
so my main concern was that the piston ring or something else was off, but using my wife's food scale.
I confirmed that everything matches up.
I'm feeling much better about the balance now. :D
And they suggested to me that i should/could run the performance connecting rod bearings for HD towing/heavy foot usage.
They did say i could skip that for the crank bearings since it's just the rods that really take the beating.
Looking through bearing options, seems to get different results using the 5.3l vs the 6.0 as a search term.
so... I'm going with the 5.3 as a search term since I'm using the crank and rods from the 5.3.
I have No idea if there is a difference, but it's odd that i get more results using summits search engine via 5.3 selected.
o_O
Also, anyone know anything about the "coated" bearings?
Looking at the "H" series bearings, i have uncoated vs molly coated.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Oh and i noticed most of the custom undersized options are apparently Narrow bearings.
wth?!
pwtr02ss
Tennessee
o_O
I have coated bearings in my camaro engine. I don't see how it can hurt anything. Keep in mind, it may add some thickness to the actual size. We ran into something like that on mine. It's been over 10 years so I can't remember exactly
Just Fishing
Just Fishing
Can't fix stupid
Utah
Biggest thing throwing me for a loop is the narrow bearings.
Economy bearings have the standard width.
Upgrade/hd bearings are a bit narrower.
Leaves a gap on the rod... there must be a reason.
I just haven't found one yet.
Just Fishing
Just Fishing
Can't fix stupid
Utah
After getting my parts back from the machine shop, I noticed the pin bores felt a little gritty.
So last night i broke out my ultra sonic cleaner and filled with some fresh mineral spirts!
heated the tank to 50c, and put each piston in there with it's wrist pin sitting next to it for a good 30 min hottub bath.
Reversed the little bag after cleaning the outside as best as I could and back into the box!
The machine shop also mentioned that they weighed each piston and balanced them to the lightest one.
Looking at their lightening marks, it seems that one piston didn't match the others in this "matched" sealed power set of pistons.
If they had let me know, I might have just opted to return those pistons and get a different set.
But what's done is done.
I'll slowly do the same thing with the rods.
And speaking of rods, the first piston i separated from the rod when disassembling the engine, I managed to put a good gash in the rod end bushing.
So i bought a new set for the machine shop to install while they were at it.
They said it didn't need it and the pins fit the rod ends perfectly.
So doing some test fitting last night, I found that the rod end that had the gash was pretty tight when installed.
So i opted to use some car polish to smooth out the gash, and then cleaned.
It's fitting much better and has free movement now.
Next the crank.
Searching around, I see that the standard seems to be a full polish of the crank.
They did a pretty rough polish.
Maybe 220/400 grit.
I'm assuming it's to help with the oil film and for some bedding in.
But this raises the question of bearing types.
First, a coated molly bearing.
Would that damage the coating?
Then the different bi metal vs tri metal...
Just Fishing
Just Fishing
Can't fix stupid
Utah
This thread needs more pictures.
I installed the piston onto one rod for now, i really need to wait to do the rest unless i find a good container to store these assembled for a good two more weeks.
I'll bag this one, but for the remaining it will be one more cleaning when I'm ready to actually start the final install.
Just Fishing
Just Fishing
Can't fix stupid
Utah
Well for this weekend tasks,
I decided i best go ahead and crack open the ATSG manual for the 6l80 to see what the pump to converter seal looks like, and the recommended replacement method.
They put in a c clip to retain it!!
Explains what i saw with the replacement that i have.
Has a nice little rubber seal on the outside.
Usually it's a smooth surface where they recommend to use some sort of locktite to prevent it from walking out under pressure.
That makes life so much easier, i was worried i would need a special tool or something in order to get around the input shaft.
worleytrev93
