tahoe no oil pressure
T
tneels
I have a2013 tahoe 5.3 ls engine. blew it up. bought a used engine put a new timing chain, oil pump, pick up tube etc etc. My son put it all on and dropped the engine in. Problem is we cannot get any oil pressure. We filed it with oil and also tried filling the oil pump from the port on the side of the motor by the pump and turn it over and still cannot get oil pressure. what are we missing or doing wrong or what can we do. I need help this is our only vehicle I spent a ton of money putting this used engine in and still owe a ton of money on this car. we haven't been able to drive for 6 months help
Tahoe14
Central Fl
If there is a problem most salvage yards have a warranty if thats where you purchased from. Hopefully you can get this one repaired. Good luck.
Foggy
KS
Did you replace your oil pressure sending unit AND filter on the new engine????
The little filter might be full of trash from the old engine so it's not getting
pressure to the sending unit
HD_LS
When you say "filled from the side," Do you mean that you did the required priming procedure by feeding pressurized oil into that port?
Geotrash
Dave
Richmond, VA
Sounds like a stressful situation and some bad luck thrown in. Lots of people here with a ton of knowledge and experience with these engines.
The most important next step you can take, as has already been suggested, is to put a mechanical oil pressure gauge on that engine and crank it but take out the fuel pump fuse and relay so it won’t start.
Murfs66
first off, how are you checking the oil pressure? From the original gauge? Someone said here that you should change the sending unit and also the little filter underneath that. I've seen many trucks running and driving with no oil pressure on the stock gauge until they replace the little filter, then thy are good to go. otherwise put in a temp aftermarket gauge to check it.
No oil pressure when running? As indicated by the gauge on the dash? Does the gauge move at all, maybe with RPM?
T
tneels
We did all of that. still nothing. It's for me confused
T
tneels
We have a mechanical Guage on it and replaced the screen as well. Still nothing. I did start it finally after cranking it over and over and over and revved it up to 3000rpm and Guage shot up to 20psi for a second then when I let off the accelerator it drops to 0.
T
tneels
So new oil pump new ouch up tube with o ring new screen mechanical Guage still no oil pressure at the top of the motor did get 20 psi after I started it and revved it up to 3000rpm but when I let off the accelerator it drops to 0. I cannot figure this out also put in a new vlom
St. Louis
Have you pulled the valve covers and checked that all the pushrods and lifters appear to be ok?
Foggy
KS
That used engine prob has bad cam bearings or bad main bearings... therefore no
oil pressure.
If you started it up or even cranked it a lot before you primed the new pump the correct way
as mentioned before, You may have ruined the new pump and the used engine...
Sorry
Foggy
KS
Also, what oil filter are you using..???? Maybe you have a clogged filter or a bad one..
Anything IS possible here... Just trying to help
T
tneels
I never turned it over before priming the new pump.
T
tneels
I was just told to try changing the filter. We have an acdelco filter in it now. I was thinking of changing the filter and doing an engine flush then draining it and changing the filter and oil again
T
tneels
Also did pull the valve covers and all the lifters and push rods appear to be OK
BadDaddy2003
