2007 Tahoe 5.3l AFM DOD delete thread
Taheezy_88
Taheezy_88
Where did it crack???
Not sure about the ARP bolts but I wouldn't think it would differ from factory specs...
I got the new oil pan in place haven't torqued yet kinda scared TBH.
In the middle of putting on Exhaust manifolds but lining them up is a pain in the ass.
Almost there...
Taheezy_88
Taheezy_88
Those are the same ones I have. They are great quality and fit well.
Cool cause I was worried about fitment issues.
I got the top end done all is left is the new headers, and differential. I've been milking this rebuild
Where on the oil pan did it crack? Can't tell from the close-up pic. There should be no reason for this to happen if everything is installed correctly. The alignment of the front and rear covers is very critical. If one point of a cover is below the block skirt, it'll interfere with the oil pan.
Double check everything and don't forget the RTV at the four points.
Taheezy_88
Taheezy_88
RTV the engine block four points or gasket/oil pan?
Tomorrow I will triple check everything.
As far as cracking I'm not sure if it was my torque sequence?
You put it at the four points where the covers meet the block. Two at the front and two at the rear:
I wanted to mention the cover alignment cuz the tolerances are pretty tight. They all screw into each other. You didn't remove the rear cover so that's not a problem. IIRC, you used a tool to center the front cover. This centers it around the crankshaft so the seal is centered. But, the cover can rotate a degree or so in either direction around the crankshaft and tool cuz there's enough slack in the bolt holes. This would make the bottom points of the front cover either too low (protruding down where the oil pan flange would hit it) or too high (too large of a gap). Think of it like a see-saw where the seal around the crankshaft is the pivot and the bottom corners are the seats. When one is low, the other is high.
I saw the cracks in the pan. I was asking where on the pan are they, like the general location- front left or right side, rear left or right, etc.
Taheezy_88
Taheezy_88
The cracks came from the left drive side of the pan near the oil filter.
As for the RTV good thing I haven't torqued down the oil pan. Ill have to drop the pan a bit and apply the RTV in those areas. I rtv the gasket/oil pan.
Sent from my SM-S215DL using Tapatalk
Maybe you were tightening up that bolt too much ahead of the others? You can use a razor blade or some other straightedge on the rail of the block where the pan goes. Slide it along the rail towards where the front cover is. If the straightedge hits the front cover like a dam, then the cover is protruding too far. Chances are, the one on the opposite side will have a small (really small!) gap. You need to not have anything hanging too low nor do you want it too high. If one side is low, it'll need to go up. But, the opposite side will need to go down. Otherwise, your seal will no longer be centered.
Taheezy_88
Taheezy_88
What are the chances of breaking an oil pan bolt while torqueing? I've just read it happens in other threads.
Checking pan alignment now Iamdub
Edit: Timing cover was a hair off with oil pan. I rtv the hell out of every corner and have it sitting now.
Juan83
Michigan
This thread is amazing! I’m doing the same exact thing on the same exact motor for the same exact truck as we speak! Thank you guys for all the help and info. I have a few questions also..I took my motor completely out just because I wanted it on the stand to do all the work. Is there anything special I have to do to the oil pan when reinstalling? I saw in another article somewhere they were drilling and tapping it in the corners. I’m ready to get mine back together asap and will continue to follow this thread thank you guys!
The only oil pan bolts I've ever heard of people breaking are the two long and skinny ones at the back. They don't get torqued to nearly as much as the others on the rail.
Good catch! It'd suck to crack another pan.
I pulled mine to be easier to work on and to replace all the seals. All the covers- front, rear and oil pan are designed to work in concert with each other. Alignment is crucial and there are specs for it. Install the front and rear covers first focusing on being centered to the crankshaft. But, they also have to be "clocked" properly. Meaning, centered on the crank but not rotated any so that one side of the bottom edge is below the block skirt and the other side high. Otherwise, when you tighten the pan to the block, it'll hit that point of the cover that's too low and not sit flush. Tightening the pan bolt will try to bend the pan and it doesn't bend, it cracks. Inversely, if one side is too high, then tightening the pan bolts will pull down on that side of the cover, off-centering the crank seal which will make it wear unevenly and wear and leak much sooner.
I don't know anything about drilling and tapping the oil pan in the corners. The only oil pan drilling I know of is to drill out the rivets on the factory original gasket or drilling the pan to install a turbo oil return or drilling and tapping the drain boss to repair damage from over-tightening.
Taheezy_88
Taheezy_88
My cover is off. To realign the timing cover? Would unbolting balancer bolt be a step or working around it unbolting timing cover to readjust?
Juan83
Michigan
Okay yes I noticed the original gasket is riveted in so maybe that what they were drilling out thanks!
Juan83
Michigan
So another question..sorry to be high jacking the thread, but what are you guys doing as far as a break in procedure? Are we doing it? And if so, what kind of oil and lube do you guys recommend for reassembly and the break in period?
You don't have to unbolt it. They make tools to center the cover, both with the seal in place and without. The one that does it with the seal in place is basically the same outer diameter of the pulley where the seal lip rides, but the inside is machined ever-so-slightly larger than the pulley so it can slide on and off the crankshaft. I use the pulley, pressed on just enough to protrude past the seal, to center the cover. I apply very light pressure to the bottom so that the weight of the cover isn't pulling down on the seal. I eyeball the bottom of the cover so that it looks even then finger-tighten the bolts to hold it in place. Then I put a straightedge against the pan rail of the block and adjust the cover with very gentle taps until both sides are even, and not below the pan rail. There's a maximum height spec that the bottom of the cover should not exceed. I aim for flush or nearly-flush, but the centering by the crank usually has it higher than the rail by something like half a millimeter. If I did this more often, I'd definitely have the tool that centers the cover without the seal in place.
After an AFM delete, the only thing to break in are the lifters, cam and oil pump if that was replaced. I use whatever assembly lube I have on hand at the time. The lifters are manually primed then soaked for days, weeks or months (depending on how long I have them) in cheap conventional 10w-30 oil (Super Tech from Walmart). I pack the rotors of the oil pump with assembly lube to help with suction for priming. For pre-lubing and first start, I use the cheap 10w-30 and good filter. I run it through a full warm-up, then for about 10 miles. I change the oil, using more of the cheap oil and good filter for a few hundred miles, then change it with a quality full synthetic and filter and resume my normal 5,000-mile oil change intervals.
Taheezy_88
Taheezy_88
Anyone got the torque specs for the:
Rack and pinion?
Front crossmember?
Drive axle 6 bolts to differential?
Thx
1BADI5
DMV
Yup, this is pretty much the same process I use.
New lifters sit in an oil jug with fresh oil for 48 hours, pump is primed with Royal Purple Tuff Stuff assembly lube. Once the motor is back together before the first start up i pull the primer port on the drivers side of the block and fill with the same assmebly lube.
Cam, lifters and oil pump were all happy, 50+ lbs of oil pressure at start up and no noise after about 10 seconds.......just the marriage of new parts getting to know each other.
Since my rebuild I have about 4500 miles on the motor and probably 20 runs on the dyno. All is good here.
veteran111
