cfmistry
- Joined
- Dec 5, 2018
- Posts
- 249
- Reaction score
- 424
Raised her up to a 2/3" drop from a 3/4". The rubbing was too much, and I actually think it looks better as a 2/3".
They're now on my wish list.That’s what I thought. I figured what I spent on the kit, I’d more than save by doing it myself just in the first set.
That’s a great stance. The sidewall of the tires is about equal to the fender gap=Raised her up to a 2/3" drop from a 3/4". The rubbing was too much, and I actually think it looks better as a 2/3".
View attachment 273995View attachment 273997 View attachment 273996
Where'd you buy the struts from? Link?Swapped out struts in the front and replaced the sway bar links. Spring compressors I bought were rock solid.
Went AC Delco for both.
View attachment 273983 View attachment 273984
ACDelco 580-434 GM Original... https://www.amazon.com/dp/B00BEGFB4E?ref=ppx_pop_mob_ap_shareWhere'd you buy the struts from? Link?
That's clean. I dig that look. Wish the paint on my 07 looked that good.Raised her up to a 2/3" drop from a 3/4". The rubbing was too much, and I actually think it looks better as a 2/3".
I have never seen a set that I can borrow from a auto parts store that I trust.
Here is what I got off of Amazon.
Shankly Spring Compressor Tool (2 Pieces) - Heavy Duty Build, Ultra Rugged Coil Spring Compressor, Strong and Durable Spring Compressor with Safety Gu https://www.amazon.com/dp/B071DQJG24/ref=cm_sw_r_cp_apip_yUWAnYSdKGPRJ
Well after trying to figure out my brake issue the front hub started making little noise today. Guess that could be the issue. Bought the moog hub and it lasted just over a year
Whats the better one thatll last more then a year atleast. delco, dorman or timkin?
Bump.What have you all done for the smaller ground lead to the core support when doing the big three upgrade?
Bump.
Did you just crimp or solder it into the new battery terminal?I just reused the original.
Well finally got around to checking out what is wrong and before I got the laptop out I jacked it up and checked the front wheels because I heard a rubbing noise. Find out it’s the FR wheel bearing/hub. The whole wheel was wiggling. Anyways 250 bucks and 2 hours later all done codes gone and fixed.@Rocket Man i definitely concur with the wheel speed sensor. The lights went away and came back as soon as I pulled away. I need to check which one. Good call
Save up for the other side, it won’t be far behind.Well finally got around to checking out what is wrong and before I got the laptop out I jacked it up and checked the front wheels because I heard a rubbing noise. Find out it’s the FR wheel bearing/hub. The whole wheel was wiggling. Anyways 250 bucks and 2 hours later all done codes gone and fixed.
now I got a lot of catch up reading to do...
Oh yeah don’t I know it. Also almost time for brakes. And my cv boot is broken. Going to need an axle soon too but this fix gets me back on the road for a bit because I don’t have another car right now.Save up for the other side, it won’t be far behind.
I figured $250 got both sides. That’s what I just spend at Rock Auto.Oh yeah don’t I know it. Also almost time for brakes. And my cv boot is broken. Going to need an axle soon too but this fix gets me back on the road for a bit because I don’t have another car right now.
For Timken?I figured $250 got both sides. That’s what I just spend at Rock Auto.
Yep. $122 apiece.For Timken?
