Guess what time it is? Surprisingly I managed to put 2000 miles on it since the trans was installed, 5 miles at a time. And now it’s supposed to rain for a week so it might be a minute before this happens. I got a Lubelocker gasket this time so there will be ZERO use of RTV. I hope the trans lasts this time around and according to Performabuilt it will, as long as I don’t clog the damn servo passages with silicone.
Just watched an informative video on some 4l60/65/70 basics that covers installation, coolers, flex plate, converter spacing, etc from Performabuilt. Ryan, the guy in the video, is the one who figured out my issue with breaking parts including the output shaft due to my use of RTV on the pan gasket which caused the servos to not release and he talked to me on the phone for quite awhile after my second failure. These guys are the best in the industry and in fact covered my rebuild under warranty even though it was a year past it AND it was my fault. It’s an hour long but there’s some good info including why the dipstick is wrong on almost every one of these transmissions and you might be running 2 quarts low and don’t even know it, plus how to mark it correctly the next time you have the pan off to replace the filter.
https://fb.watch/42QfVsqNTm/
NoReverseYukon
NE Wisconsin
Any chance you could give the time stamp of when he talks about the dipstick ?; an hour + video is more time than I can watch when my to-do list is so long. Thanks.
Replaced the trans filter today. It wasn’t too bad, luckily the ARH midpipes come off easy and I just bent the shifter bracket a little bit so the pan could drop down. The magnet looked pretty good, just a bit of fine material but nothing to be concerned with. I’ll cut the filter open tomorrow to check for friction material but I don’t expect much. It’s just broken in with 2000 miles on it. I checked the dipstick to see if the crosshatch was at the pan gasket line as per Performabuilt’s instructions and as far as I can tell it’s good. It’s kinda hard to tell for sure since the seal hangs down but it looked close. The pan has been on and off a few times and it wasn’t flat around the bolt holes anymore so I ran to Oreilly and bought a Dorman one that has a drain plug because it sucks dropping a pan without one. Plus the OEM ones are 3x as much and don’t have a drain. There’s not many Dorman parts I’ll use but a stamped steel pan can’t be ****** up I don’t think.
46180A55-A000-445D-BE23-6ECEB50AE69F.jpeg 4E992021-FD81-4918-9480-83728A93C5A4.jpeg B2056ECF-0798-4CEE-9E66-C158FE9AA87F.jpeg 4D9D0F09-2274-4E99-A85A-24A4C4304161.jpeg 18B27237-092D-495F-8E89-21E59D4F8D2A.jpeg
Opened up the trans filter. Nothing to worry about, just a couple of tiny pieces of metal which interestingly were on the interior of the filter media, sandwiched inside. It does only have 2000 miles on it but I’m not seeing any frictions that I can distinguish. I was expecting some. The black plastic shavings are from me drilling out a plastic rivet thing in the center.
B071B6C2-974C-45AA-9A6C-68E58C519539.jpeg CE8746C1-5D20-44A7-A23B-2D63DEDDFAFF.jpeg 2F6055A3-B318-4809-8D93-6312C6234266.jpeg E5E23762-7FA1-4BFF-B93A-E150A698F450.jpeg C96D3583-6FF4-4845-AC55-90D5905EF075.jpeg
Made a dump run today and found out again how heavy this thing is. And some idiot in a Kia Soul tried to take me from a light to cut in front of me. Which he did cut in after I let up, figuring he gave up since I whooped him but instead he kept going past where his lane ended and made an ******* last ditch effort, almost hitting my front bumper. At the next light he tried the same thing, it was 2 lanes both turning right then right again into a freeway on-ramp. I didn’t give him a chance this time and hit 90 by the bottom of the ramp and saw him in my rear view way back there. I hate those little ugly things lol.
Sam Harris
Douchebaggery! I had a day like that yesterday. Then when the ******* had to wedge behind me, after losing, he had the balls to flip like 15 gestures at me. It’s probably a good thing I carry. Keeps me from reacting to these morons.
I would've just ran his ass into the ditch--meaning I'd keep going straight and maintain my speed-- and kept moving--that's just me tho.
Unfortunately by the time I realized what he was doing it was too late. Once I let off the gas and it upshifts, by the time I punch it enough to downshift and build boost again it’s over. The rpms had already dropped so oops. I wasn’t really trying that time, figured half throttle would do it which it did but he came from behind after I got out of boost and shifted. It’s ok, that time he was on my left but the next time he was on my right with his window down a couple inches, and I hit him alongside the head with pretty much straight pipes since my exhaust exits on that side. I can only imagine how loud that was for that first 100 feet (actually maybe 20 feet lol) before I left him. He was all happy sitting there thinking he was gonna get me again, sucker had no idea what was about to hit him. :)
Unfortunately by the time I realized what he was doing it was too late. Once I let off the gas and it upshifts, by the time I punch it enough to downshift and build boost again it’s over. The rpms had already dropped so oops. I wasn’t really trying that time, figured half throttle would do it which it did but he came from behind after I got out of boost and shifted. It’s ok, that time he was on my left but the next time he was on my right with his window down a couple inches, and I hit him alongside the head with pretty much straight pipes since my exhaust exits on that side. I can only imagine how loud that was for that first 100 feet before I left him. He was all happy sitting there thinking he was gonna get me again, sucker had no idea what was about to hit him. :)
I really despise a$$holes like that.
Sam Harris
Hahaha! Take that shit in your ear Douchebag! Lol. I feel the same way, since I have the ARH headers (thanks to your recommendation Mark..) and side exit. Although, I have cats and I don’t think you do.. that makes a significant difference...!
I have ARH’s high flow cats but my muffler is an Aero turbine that actually amplifies the sound instead of quiets it down so it’s loud af. :devilfinger:
pwtr02ss
Tennessee
I have found smiling and blowing a kiss works wonders. That usually sends them in to orbit lol
I just hate it when I don’t know somebody’s gonna try to jump me at the line so I take off normal and the 4l60 shifts into second and then I mash it but it stays in second so I can’t build boost fast so it takes a minute. If I mash it immediately it stays in first to redline and it’s pretty quick for a 3 ton machine. I’ve surprised a lot of folks but I have to be careful not to break shit at that point. Maybe I’ve finally weeded out all the weak parts, I sure hope so. I have no idea how Randeez doesn’t constantly break shit with all the power he’s making. AWD is ******* parts. Especially in reverse. :signs8:
pwtr02ss
Tennessee
Talk to BB, they should be able to fix that 2-1 shift in the tune. Command downshift at a lesser % of throttle (I think).
Sam Harris
Hmm... it seems to me that a trans brake, and a 2-step are in order Mark..!
I washed both trucks and the bike today, trying to use up the last of the CG Honeydew car wash so I can break out the watermelon I just got today. It’s supposed to smell just like watermelon and I’m in the springtime mood.
E93FB28D-564C-4656-A18E-E856E37B041B.jpeg 29CACBA3-12FD-46B7-A56E-1A356293182F.jpeg
Drewphil
