Brackets for lower portion of the bumper, need help.
Ilikemtb999
Denver
So my ssv used to be border patrol and originally had a cut bumper just below the crash bar and still has the full skid plates installed. Well over time the current full bumper is flexing so much I’m getting some paint coming off in the corners by the grille. I purchased what I thought was the lower bumper bracket pieces but I feel like I’m still missing something. Anybody have a picture of behind their front bumper?
heres mine.
249CA165-08A6-4FF3-81F1-6958EFC1FB33.jpeg A19D0459-6B58-4339-B88F-A11497CD227D.jpeg E8A38939-7114-4CBA-A3AB-654A5A378CA9.jpeg EC9B4336-9F1D-4D45-A6DA-D11D5432B93C.jpeg
DRayson
I have the same issue (no lower bumper support) just picked up a 2013 suburban 2500 that was ex border patrol. I work at a repair shop, the next Tahoe/burn that comes in I will try to see what all is missing on mine and report back if you still need the info
Ilikemtb999
Ilikemtb999
Denver
Nice!
I installed the corner support pieces but seems odd there’s nothing in the center area. My Yukon has a metal bumper so very different.
DRayson
Have one in the shop now. There is a piece that is welded to the crash bar that comes down and the plastic supports you installed attach to that.. looks like we will need to pull a crash bar from a scraped hoe/burb to get it back to factory
Ilikemtb999
Ilikemtb999
Denver
Probably why the covers all seem to crack then around the grille corners. I’ve seen a few used ones like that.
I’ve been thinking about going back to the BP look again and just cutting it.
Sparksalot
Bastrop County, Texas
I’ve been thinking about that too. The washer fluid tank hangs too low, so that would have to be reworked.
Bill 1960
Testing the Limits
There are small rectangular aftermarket tanks for washer fluid that will fit in alternative locations. Did that mod on a Jeep. Eventually I’ll be doing it again on my Hoe because I’ll add a second battery.
DRayson
Is there nothing that supports the middle lower portion of the bumper cover?
No, the middle of the bumper has no additional support. The air dam along the bottom of the bumper makes it more ridged, not sure if yours has one of those or not. I find it hard to believe that one bracket on the sides makes it that must sturdier but that’s all it is
Ilikemtb999
Ilikemtb999
Denver
Yea it does have the lower lip, still seems so flimsy.
Conedaddy
