2004 6.0 NV4500 Tahoe
randeez
south florida
I dont know....I want to redo the entire hot side, with some up and forward headers so I can slam a 5"dp out of the engine bay, position the turbo to suck in some air other than right behind the radiator
I dont think ill get much more out of this turbo power wise, but prob make it breath a lot better.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Huh, I'm not sure your current turbo would be a good fit for a wore out lq4 that only wants 6-10psi, probably take awhile to spool. But IDK shit about turbos TBH. What down pipe do you have now 4" or 3.5"? I do know I want a bigger DP than 3" to keep EGT low on long towing grades, pretty sure Rick always specs T6s for towing.
You gotta lick it before you stick it.
It's hard to lick with a mask on.
randeez
south florida
4"dp, but you get to make all the faces without them knowing under your mask
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Well well next problem has risen, actually something it's had for a while but I assumed was worn suspension parts that have now all been replaced.......
The symptom is as follows: Driving over 45mph on a straight and smooth road 5th gear and let's say cruising throttle maybe 20% all is well. As soon as I lift off the throttle leaving the truck in gear it seems to push over to the left. If after I left out I then apply the throttle the truck will push to the right. Both are dramatic enough to need steering input to correct.
At first, I assumed it was the busted ball joints/steering arms however, since replacing them all I think it may have gotten worse. There is literally no steering arm, spring, shock, joint, or bushing that hasn't been replaced in the last 365 days except for motor mounts which don't appear to have any abnormal flex.
Totally spitballing but maybe the G80 doesn't like the sudden application or revocation of power and it's pushing the truck one way or the other?
Gotta be something like that. You’re 2WD, right?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Yep, which kinda eliminates the bad alignment from causing torque steer. This was a minor issue before the front end rebuild so I don't think its alignment related anyway. I did some more testing of it this morning and it pulls left when letting off the throttle and right when applying throttle, also more noticeable above 55-60mpg.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Motor mounts would do that, even though I know you said you checked them
That keeps bouncing around in my head since it's the only thing I haven't replaced. I visually inspected them and I don't have any of the common symptoms like header clearance issues but I have not watched the engine while someone revs it. That will probably be tonight's investigative work.
bigfootchiro
Largo, FL
That's a good idea. Any other bad noises during takeoff or cruising down the road?
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Nothing that stands out no, the trans always makes a little noise but nothing crazy and every NV I've driven makes the same little bit. I'm gonna check the motor mounts tonight, I really don't want to replace them not sure if it's possible without unbolting the trans. I'll likely go with OEM replacements if they are shot, The atomic mounts are awesome but they suck to install, everything is so tight.
The OEM mounts in the NBS rarely go bad. They’re not fluid-filled like the NNBS.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
The fluid filled ones are definitely worse
Is that because people don't check their motor mount fluid? :jester:
I would look at something in the rear suspension. Maybe something loose or a bad bushing allowing the axle to shift cause the change of direction??? :shrug:
Last week, when I put the new shocks on I grabbed everything and gave it the ole Wiggle-wiggle. Nothing seemed to move which doesn't rule out worn components but since they are all new I find it less likely.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I thought that was always a part of maintenance. You're supposed to check your muffler bearings, blinker fluid, and motor mount fluid at the same time, along with your air filter battery and radiator hammer tap test.
I don't do the radiator tap test in winter because I emptied the coolant to help it warm up faster. :p
dizhai
