Denali Airbag/Steering Wheel Emblem
Hi-psi
Atlanta, GA
Anyone know of a source to get a Denali emblem for the center of the steering wheel? I know GM doesn't sell these by themselves, but they can be replaced by removing the airbag.
I can find ones that just say GMC, or SS, or are bowties, but so far haven't found anywhere selling ones that say Denali.
Mine has a scratch or two on it and I'd like to replace it.
Example of what I'm looking for...
adventurenali92
Big Bear Lake, ca
Have you looked on eBay? I picked up one for my generation from an envoy Denali with the Denali logo. And there were tons of Denali logoed airbags for that generation.
Hi-psi
Hi-psi
Atlanta, GA
I have. Either there aren't any at the moment, or I'm not searching the right terms. Finding tons of bowties, or standard GMC ones, but no Denali ones. Only complete airbag assemblies with the cover included (that has the emblem).
Hi-psi
Hi-psi
Atlanta, GA
Those are the complete airbag assemblies. Airbag, cover, & emblem.
Not what I want/need. I'm looking for JUST the emblem. As mentioned, I've found GMC ones, bowtie ones, "SS" ones, but not any that are just "Denali".
VDV18
Could you find a blank one and have a local shop that paints motorcycle tanks customize it? Then it doesn't even have to say Denali.
adventurenali92
Big Bear Lake, ca
I didn’t know they came separate. I’ve never seen them that way. Maybe the Denali covers don’t come seperate. As he said above see if you can get a blank one. I’d then take the blank one to a print shop that can make a vinyl Or printed over layy that says Denali on it. If you can’t find one that says Denali already on it.
Wolfbraid
Winston Salem, NC
Try contacting the seller, they usually have a source for these, and probably don't stock the Denali ones due to low demand.
NathanJax
Vacation Nathan
Jax, Fl
I got mine off eBay and replaced my dented one. Pics in my Silverado build thread.
Wolfbraid
Winston Salem, NC
Did you ever get one..
Ledesordre
Is there a good method for installing these? I tried installing one and messed it up even worse than the one I pulled out.
NathanJax
Vacation Nathan
Jax, Fl
Gravatar
Found a good video for installing one, but haven't found a source for a GMC logo.
cfmistry
It is WELL worth it to pull the airbag and out the emblem in the right way. It takes 20 minutes total even for a first timer.
I tried the “shortcut” method of replacing the emblem with the airbag in and it ended up looking horrible. I had to redo it since I messed the new emblem up so bad. Glad I didn’t take a shortcut the second time around, it was easy and looks perfect.
Ledesordre
Glad this thread is still getting bumped. I still need to do this.
Cliffvt4
I ended up having one made by ReBadge Design (rebadgedesign.com). Simply pulled off the old scratched metal badge (no need to remove the air bag) and replaced with their new badge which sticks on the vinyl behind the old badge. Looks factory. Great company willing to do custom work. Check them out. 1CD475B4-0021-4D3D-837B-8DDC68BF39DD.jpeg
TejasPitt
