randeez
i meant it in the nicest way <3
yes the coil over assembly is at its max extended length until you put the weight of the vehicle on it, which you want it to compress the spring into the happy zone (ride height) of the shock.
you need to determine the length between mounting points at ride height, spec a shock that has a decent balance between compression and extension at that height. the shocks have a spring length to follow for the most part, 8"10" 12" or so. that allows the full use of travel by the shock without running into coil bind on the spring.
if the spring wasnt captured then yes, he would just be moving the lower perch.
from the site he linked:
SETTING THE RIDE HEIGHT RIGHT
Chances are you picked up that set of adjustable coilovers for no other reason than to establish a specific ride height. Many coilovers allow you to do this in two ways: by compressing or uncompressing the spring by way of a pair of jam nuts at the spring perch—which will alter preload—or by threading the shock's base up or down—which will alter shock travel.
he cant alter the shock travel as expressed, it has a set compressed and extended length
