2004 6.0 NV4500 Tahoe
randeez
south florida
i meant it in the nicest way <3
yes the coil over assembly is at its max extended length until you put the weight of the vehicle on it, which you want it to compress the spring into the happy zone (ride height) of the shock.
you need to determine the length between mounting points at ride height, spec a shock that has a decent balance between compression and extension at that height. the shocks have a spring length to follow for the most part, 8"10" 12" or so. that allows the full use of travel by the shock without running into coil bind on the spring.
if the spring wasnt captured then yes, he would just be moving the lower perch.
from the site he linked:
SETTING THE RIDE HEIGHT RIGHT
Chances are you picked up that set of adjustable coilovers for no other reason than to establish a specific ride height. Many coilovers allow you to do this in two ways: by compressing or uncompressing the spring by way of a pair of jam nuts at the spring perch—which will alter preload—or by threading the shock's base up or down—which will alter shock travel.
he cant alter the shock travel as expressed, it has a set compressed and extended length
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Damn shots fired from the Randy!
But he is right that preloading doesn't change the spring rate. "By now you ought to understand preload won't change your spring rate, and when applied conservatively, it won't affect handling. Every spring should be subjected to at least some preload."
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
On another note Summit thinks my Hellwig package was damaged in transit and repaired by UPS. They are sending me a whole new 7702 kit bar, bushings, brackets, and end links. If someone is interested in a front bar let me know, would prefer to not have to ship it.
Now I'm confused as to what we're talking about. Talking about his coilovers uninstalled, unloaded, sitting on his work bench, at the supplier's warehouse, etc. is pointless as far as I'm concerned. He has them installed. They are compressed X amount- both the springs and the shocks. If he were to raise or lower the perch, the spring and shock piston/rod would raise or lower that same amount. This would lift or lower the truck. But the load capacity, spring rate, ride quality, etc. wouldn't change. The spring wouldn't compress unless he raised it so much that the shock's length were maxed out and he continued cranking up on the perch.
randeez
south florida
If he were to raise or lower the perch, the spring and shock piston/rod would raise or lower that same amount. raising the perch doesnt raise the spring from a position stand point, it applies preload. you can only lower the perch until there is no preload on the spring, if you lower it beyong that the spring will be loose in the shock when suspension unloads
This would lift or lower the truck. correct with the springs ability to support weight though.
But the load capacity, spring rate, ride quality, etc. wouldn't change. pretty much correct, load capacity and spring rate dont change. you can put too much preload in the spring and ride quality will suffer if youre using wrong spring rates, ie if dan wanted 36" fender height so he added abunch of preload where the truck would sit another 1.5" higher. he would have a lot more energy stored in the spring to overcome before he would have any compression on his suspension.
The spring wouldn't compress unless he raised it so much that the shock's length were maxed out and he continued cranking up on the perch. im not sure where we are not connecting, for these coilovers that is exactly what has to happen. you cant have the spring loose between the perches.
if the extended length is 20" a spring with no preload is going to compress with the vehicle weight on it.
the same 20" shock with 4" of preload on the spring is not going to compress at all until you over come that stored energy. its still 20" long tho
I still don't get it. There is no "preload". The weight of the vehicle is on the coil, so the coil is loaded. I guess you could call that its "preload" since there would be more loads to come as he drives. It would be loaded more (dynamically) as the suspension is compressed during driving. But, it's just loaded nonetheless. With the weight of that corner of the vehicle on the coil, it will compress a certain amount until the spring rate and the weight acting on it balance out and that's it.
Here's my angle:
If I were to hold my hand out and set a lightweight spring in it (think wastegate spring), then set a 5 lb book on top of that spring but kept my hand perfectly still, the spring would compress X amount. If I raised my hand, you're telling me that the spring would compress (assume more preload) while the book would remain at or very near the same height in relation to the ground?
I bet that if Dan cranked up on the perch as far as he could without hitting the maximum extension of the shock and measured the coil's overall height, then lowered the perch as far as he could without the shock hitting its internal bump stop or any other suspension component hitting whatever limits its movement and measured the coil's overall height, the two measurements would be the same, within a tiny fraction. There would be a little weight change acting on the spring due to the shifted weight of the vehicle.
randeez
south florida
theres no preload unless you tighten the coil past the "free" length. setting the jam nut up against the spring to where it can barely move within the shock is for the most part the free length.
your analogy doesnt work because we are always starting with the shock at fully extended length before you put any weight on it. the two mounting points can never be further apart than the shock. for your analog to work it would be like putting the jack under the control arm and lifting. youre moving the mounting points not putting preload into the spring
if you start with a 20" shock and put an 800lb/inch spring on it with no preload. 2400lbs is going to compress the spring 3 inches.
same 20" shock but you put an inch and a half of preload on the spring (1200lbs) when you put 2400lbs on it there is already 1200lbs pushing back out so only 1200lbs of it further compresses the spring. because our mounting mounts are a fixed 20"apart you've only brought them 1.5" closer together with the truck weight
dans going to have to do the science
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I'm completely lost but I'm enjoying the read
Yep me too, both seem right but both seem wrong.
View attachment 268357 View attachment 268358
I think we're both thinking the other is talking about something different, which then would make what we're actually talking about incorrect, physically impossible, actually.
I just can't get through to Randy cuz we speak different colors of tie wraps. For the record, guys, he's not as stupid as he's making himself sound. Or for bantering with an equally as stupid moron on teh interwebz. It's kinda cute, actually, how wrong he is by assuming I'm wrong for assuming he's wrong when neither of us are wrong at all. Damned Florida people.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
All I know is crack is wack and Florida man got my back.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Well that ain't right. Looks like skipping the bolt that keeps the shock extenders pin in the downward position was a bad idea. I only skipped them because I couldn't find them so I swung by ace the expensive place and got some grade 8 boys.
Also measured for shocks for the third time but now I have a picture to refer back to. I also measure distance before bump out and its 4.5" which is more than I expected. I forgot to put a dab of grease to see of its bottoming out but i don't think it is. Personally I feel like the springs binding because at ride height the lower coils are already bound up tight which is odd. You can kinda see the coil in the last pic.
Also added a little more preload to the driver side it dropped about 3/4" and the passenger dropped 1/4". Brought driver up to Passenger height at 33.75" which gives it a tad more rake which is okay in my book.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
dual adjustable too? nice i still need to measure and order some new ones
Yep double adjustable or bust, I'd seriously consider the Vikings over QA1 they are a good bit cheaper. These cost me $415 that's taxes delivery everything. I think the QA1 DA were about $300 each plus all the other BS.
randeez
south florida
yea thats why i was asking
just ran out and measured mine, its sitting right at 16.5". need to find the sheet that lays out all the sizes for the vikings
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Eickybobby5050
