Kbuskill's 2008 Burb LTZ "MOD" Thread
kbuskill
kbuskill
NE. FL.
Trans and oil cooler lines connected ok?
My truck doesn't have the factory engine oil cooler, I purchased this radiator with the EOC in case I decide to add the factory EOC lines in the future. I have an external aftermarket EOC already so I'm in no hurry. I just left the caps in the EOC ports on the radiator to keep dirt out for now.
The transmission lines popped right into the quick disconnects beautifully without any issues or leaks though.
Also, I accidentally lied to you about my "K&N" filter... when I pulled it today to clean it I realized that it is actually a Spectre HPR8755.
The last pic was before cleaning and re-oiling.
Well, damn. I wonder if that's where the elevated silica level is from? Did you happen to check the inside of the intake tube for dirt?
This reminds me of the lawsuit K&N won against Spectre:
"...The federal court also addressed claims by Spectre regarding the independent laboratory testing of its Speed By Spectre hpR filters, which were advertised as having been "proven to filter 99.6% of particles." The court found that the company did not select an air filter from a production run for these tests, and instead used a specially designed test filter, providing no basis to find that any of the filters actually sold to consumers would have the same efficiency as the test sample."
kbuskill
kbuskill
NE. FL.
Huh, never heard of that. You never cease to amaze me with your obscure knowledge... lol
I did wipe the inside of the intake tube and there was nothing to speak of to be seen on the white napkin I used.
This filter has been in since well before I started doing UOA and it has never been a problem before. I think it was just time to clean the filter. It was dirty, not as bad as some I have seen in the past but dirt did come out of it when it was cleaned.
kbuskill
kbuskill
NE. FL.
Well the maiden voyage of the new radiator happened tonight.
On a 20 mile ride, running 55 - 60 mph without any real stop and go traffic with the A/C off (so the cooling fans were off) the temperature stayed at 172°- 174° as seen by the OBD2 data. Ambient temperature was 70°- 71° according to the mirror.
This is right at 20° cooler than what the truck has always ran in the past.
Now I need to figure out at what temperature it goes into Closed loop mode. As long as the truck is in closed loop mode I won't worry about it.
Obscure/useless- I know, I know. I wish I was capable of storing productive info. But, I guess, that's what the intellectuals of TYF are for so that's why I come here.
Then it must be filtering just fine. Looking forward to the next UOA. You make this sort of stuff captivating to the simple-minded ones.
Interesting, and good! Among other factors, closed loop operation requires the coolant to
be more than 122 degrees for more than 30 seconds.
BTW, I found a pic of the factory rad restriction orifice:
It's tiny! So, it obviously has a significant function.
kbuskill
kbuskill
NE. FL.
Ladies and Jellyspoons... behold, Dub's way of making those with less formal education and training feel better about themselves... lol
kbuskill
kbuskill
NE. FL.
I tried to take a picture of my original but never could get a good angle. I couldn't see that in mine.
wjburken
Eastern Iowa
You sound like me. When folks ask me what I know I tell them “I know a lot of stuff that doesn’t matter and not enough of the stuff that does matter.” Oh well, it gets me invited to be on a lot of trivia teams, so that’s something I guess.
are you talking transmission temp? nevermind I guess not, I just never understood how any size radiator would make any difference on the coolant temp since the thermostat controls that and only opens at a set temperature. a bigger radiator or even a swimming pool wouldn't make the thermostat open any sooner.
kbuskill
kbuskill
NE. FL.
The LS engine has kind of a strange cooling setup. The surge tank dumps in behind the thermostat. The surge tank receives coolant from the top port on the passenger side (cold side) of the radiator.
If the radiator is cooling better than the old one and there is enough flow through to the surge tank then it can cool the engine to the point where the thermostat will stay closed, or re-close I suppose, because the cooler coolant is bypassing the thermostat and cooling the engine.
I'm not sure if the new radiator is cooling more efficiently or if the port to the surge tank just has less of a restriction in it but either way the truck ran 20° cooler last night and the only difference is the new radiator.
I thought it wasn’t good to have your engine running cooler, that’s been discussed in the threads regarding cooler thermostats. Supposedly there’s a reason our engines run the temp that they do. I can’t remember why...I’m getting old I guess. :crazy:
kbuskill
kbuskill
NE. FL.
So this evening I rode into town with my wife and some friends to get some dinner.
This time I had the air conditioner running and it was more stop and go traffic going up into town.
Ambient temperature was around 75°.
The truck appears to be running at its "normal" temperature... 192°-194°.
So I'm guessing having the heat from the condenser in front of the radiator, combined with the stop and go from traffic lights made the difference.
That wasn't my intent. I don't have any formal education beyond 9th grade and my "training" is accumulated from a lifetime of ****-ups and, eventually, internet research.
I honestly do have issues with retaining knowledge applicable anywhere else in life other than the garage. Two track mind: **** mounds and motors.
Also, I honestly do geek out on your oil filtration system and UOA results. Like I said- simple pleasures for simple minds.
Thermostat's aren't a precision instrument. lol
Even with the same ratings, it's common for them to open and close at temperatures 10 degrees (maybe more?) different from each other. Beyond that, some open or close more or less at a given temperature. The "balance" in a system can easily be altered by changing the largest component. A 20 degree difference is a bit much, though.
The other (and possibly the sole contributing) factor here is the surge tank style of system we have, as Ken outlined. Some people have issues with the engine not warming up quickly enough and throwing codes. I doubt this would be a problem on most days in Florida.
kbuskill
kbuskill
NE. FL.
I was just giving you a hard time buddy. I appreciate the fact that someone gets something out of my limited mods.... and folly... lol
kbuskill
kbuskill
NE. FL.
So today, another 20 mile trip with A/C off, ambient temperature about 70°, less stop and go traffic and red lights... truck stayed about 20° cooler at 172°- 174°.
Any of you guys with access to the OBD2 data stream interested in checking to see what your temperature is while running the A/C and then again without the A/C running, while up to operating temperature???
I am just curious to see if there is a difference with your truck as well.
I never thought to see what temperature my truck ran without the A/C on, while cruising, before swapping radiators. Didn't really think there would be a difference.
BadDaddy2003
