Don't always trust your mechanic, fixed my "blown" engine for $7.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Awesome find and congrats! If it weren't you, it would've been someone else. We all need a break every once in a while. She could've taken it to another shop but she didn't. Glad you got er fixed up.
I have to admit it’s nice to catch a break. Years ago I picked up a 86 olds 88 for $500 because the shop told the customer the cam was wiped. I took the valve cover off and found so much sludge. Decided to do a major engine flush and see what happened. After a few oil changes she purred quietly. Sold it for $2500 a month later.
73TA
I do plan on contacting her and letting her know that they had misdiagnosed her engine. Not sure I will tell her that it was just a spark plug though, might say it was a broken valve spring to help ease some of the pain this.
Decided to buff it out, wanted to cleanup the tree sap, scratches, etc., before I tackled all the little problems listed below (I guess the oil pressure switch/sensor would not be a little problem based upon the light show on the dash).
A buddy of mine that I sold my 07 C6 z51 6 speed to brought over his HP tuners (did not have to buy credits to connect and run codes) and was able to connect and find the brake switch code and check a lot of the other operating variables of the engine while it was running that my Foxwell scanner would not do.
Not a much of a fan of black wheels so I put the stock chrome 22's (the tires look like they only have a few thousand miles) back on and replaced all the center caps with a set from Amazon. Caps were real nice and fit well.
Wanted to detail the outside before I posted pics, will upload them tomorrow.
Still got a short list of minor known Esky problems to address.
1. Repair/Replace a faulty front impact sensor, common problem (Airbag light on). Second on my list to do tomorrow.
2. Repair/Replace driver’s side door latch assembly (interior lights don't come on, other doors turn them on.
3. Replace brake switch under the dash (brake lights work fine, got a code, haven't tried the cruise yet, probably doesn't work)
4. Replace oil pressure switch/sensor with new AC Delco part. Dash still have all the usual fault lights event thought the cylinder 6 misfire has been fixed with the new plugs. Part will be in tomorrow, first thing on my list to do.
5. Heated seats don't work, another common problem, will check the fuses and module wiring under the passenger seat.
6. Power running boards don't work, another common problem, will check the fuses, connections, and lube everything.
7. Rear backup camera does not work, another common problem will check the fuses and connections.
Fortunately I have a 2009 I bought for parts Tahoe to get most of the parts I need.
I assume that there is a stuck CD in the player, could not load one. Will get to that later.
I actually plan on taking it on 150 mile road trip on Saturday to Lake Coeur D'alene this Saturday, just wanted to get all the lights off first, If a get to all the little stuff before then I will consider it a bonus.
Mike
GMT800 2005 Tahoe Z71
Navy Supporting Member
I think Coeur D'alene is where BBT is? Right?
I agree with @BlaineBug, I would not say anything to her for fear of her feeling bad and maybe raising hell with the shop. If she went to that shop she would need someone to be with her that understands the vehicle and can speak on her behalf.
IMO, if you feel that strongly about it I would go to the shop and ask to speak to the owner and tell him/her what took place and how you are VERY tempted to tell the lady what has happened and that if they give you grief you will tell her the whole story.
This reminds me of how I got in to auto repair in the first place. I was a photographer. just out of the service and looking for a photo journalist job at a paper or magazine. None to be had. My mom had a problem with her car and took to a shop. They told her it needed an engine. A family friend looked at it and found a vacuum leak a 2 loose plugs. I stormed in to that shop and we almost came to blows. I decided to then take my knowledge of what my dad had taught me and my desire and I went to a school for 6 months. I was then in the field for 35+ years. I hated any shop that took advantage of anyone, let alone an unknowing lady like my mom.
Mike
She might want to buy it back once you fix everything that's wrong.
91RS
GA
Sorry to say, but that engine is not fine. That fouled plug is not normal wear and tear, that thing has some serious oil consumption. It will do it again. Not next week but it will do it again. I’ve seen many plugs with 200k+ miles on them that don’t look like that. If you’re fine to just put new plugs in it every time it fouls and keep it full of oil then it’ll probably keep driving for another 100k miles. But from a customer stand point who knows nothing about cars, that won’t do.
Most people on this forum don’t understand what it’s like to be a shop. If they would have “fixed it” with a new spark plug that would have just been kicking the can down the road. At 200k, from a shop standpoint to guarantee the repair that truck needs an engine. When you band aid something yourself, you know what you’ve done and can only get mad at yourself if it goes wrong. If a shop does it the customer comes back and demands it for free.
While I agree with this and said the same about the oil fouled plug earlier in the thread, I believe she was told she needs an engine for a complete and thorough fix that they could stand behind with a warranty and I would bet she was not given other options. They may have given options like valve job or re-ring the engine or both but those options are also very expensive and don't address the age and mileage as well as a new engine would with a longer warranty. Maybe the shop did give options but in her mind she heard, "needs an engine" and only remembered/thought of that. If I was running that shop, she would have been given the option of a compression test, wet and dry, and cylinder leak down test and then given the options I just mentioned. I would have also told her that as we disassemble for whatever repair she decides on, that the ancillary items removed for access would be inspected and replaced as needed. Items like, water pump, egr valve, plug wires, coils.....etc.
BlaineBug
Clown World
It's possible that a shop can give the customer the options. They could say hey, this isn't normal, but a new fuse and a new spark plug will have you up and running for a certain amount of time, could be awhile, could not, but at least she'd have a vehicle to drive rather than nothing at all.
It's the same way with HVAC technicians or any other repair guy. Some only want to sell you brand new equipment but others will give you honest options to get you by so as long as it's safe and isn't spewing carbon monoxide into your home.
4-5 years ago I would do brake jobs and oil changes out of my garage for side moneys, advertised on Craigslist and Facebook. A guy I did an oil change for called me a few months later about a noisy blower motor in his Lexus. I showed him that it was full of paper since it was open to the glovebox, removed it all and it was silent. He ended up seeing a car I was selling later that year, called me up and bought it, and his words were "you're honest so I can trust what you're selling here." Of course I'm not a shop so I don't have the huge liability nor overhead costs that they do, but I don't think that stops a shop from NOT warranting a repair so as long as the customer signs off on it, knowing that this may or may not be a temporary fix to get them by. We're not talking about patching brake lines with compression couplings here. It's unlikely replacing spark plugs has the potential to kill anyone even if they were to get fouled up again in 10,000 miles or more.
To me, telling someone they need a new engine when they don't right away either sounds like tech incompetence or a larger scam. I highly doubt the woman would pay a shop the thousands required to put a motor in an older vehicle anyway so I'm not quite sure if scamming her was their prerogative. Perhaps just a lazy or incompetent technician?
Not everyone is Eric O. from South Main Auto with their severe in-depth diagnostics and analysis.
91RS
GA
Sure but we have no idea what actually transpired between the shop and customer because we weren’t there. Maybe they gave her options but maybe they didn’t. It happens lot just as PNW said, they hear engine and stop listening. Many people are just looking for any problem to get rid of a vehicle after 100k miles so certainly not many are going to spend much money on a 200k mile vehicle. Especially if they don’t understand cars and have no clue what they’re being told.
BlaineBug
Clown World
Could be. Maybe it just has dirty valves that need a big cleaning? Common with direct injection especially with DOD/AFM isn't it? LegitStreetCars just did a tutorial about a quick valve cleaning on his Wife's 2015 Escalade.
91RS
GA
It is somewhat common but so far not on the GM V8 engines but an 08 has neither direct injection nor AFM.
kbuskill
NE. FL.
'08 is not direct injection.
It probably needs what @iamdub suggested at minimum, but that would be a good start.
jkhuntzinger
