Service Safety Restraint System error
tomgilk
Mine is going in for the service safety restraint system Friday morning. Popped up at 1100 miles. They also have a recall on some sort of brake fuse thing, getting that knocked out at the same time as well as having the sunroof drain system looked at.
PauliePucks
NJ
I took my XL SLT in last week for BSCM recall and oddly enough we got the SRS error at 1600 miles, and a day before it went into the dealer for recall. When the dealer looked up the VIN, there was a new recall that came up that addresses the service restraint system error.
I left my Yukon for the recalls to be done. The dealer called me an hour later to tell me the BSCM update was done but that they needed to order the harness kit that is now available for the service restraint system recall.
anyone else get this info? I even provided the TSB and the fixes that I located on this forum and the advisor told me GM will only authorize this specific harness to remedy the recall. Strange.....
tomgilk
Just dropped it off. We'll see what weirdness awaits.
Paul Z
Roanoke, VA
Update- no recurrence if the problem after several hundred miles and a few weeks. Seems like replacing the connector in the steering wheel was the issue for me. I hope the relative quiet on the forum means that others have found a resolution.
Any more issues?
My 2020 Trail Boss, purchased new on 11/8/20, has had the same issue from day one. The clock spring was replaced on the first attempt and worked without issue for 4-5 days. On the second attempt, they simply disassembled and reassembled everything from the first attempt. No issues for 24 hours. It is currently in the shop for attempt 3. This moring, they told me they'd be working with GM techs and determined the airbag needed to be replaced. Seems like a shot in the dark but we'll see.
James Mill
I went through something similar with my Silverado and the piece that finally worked, thus far, was replacing the airbag connector in the steering wheel. I had to clock spring replaced twice.
tomgilk
Well apparently the part is hard to get, had some other small issues addressed but this still isn't resolved.
James Mill
Ugh. That’s frustrating, and especially on a new vehicle. It took two weeks to get mine.
Bthnc
How long does the repair for this generally take? I need to wait at the dealer or figure something some transportation assuming they won’t have a loaner. I was thinking it would be a quick thing but after reading this thread, I’m not so sure.
Paul Z
Roanoke, VA
In my experience, you're going to want to leave the vehicle and find other transportation.
Bigmanny
Bigmanny
I just had done (again today) as mine was not the official fix. Under 2 hours.
Boone450r
Bringing the Escalade in tomorrow to have this addressed, was told under 2 hours as well. I will let you know.
tomgilk
They got my part and fixed it quickly and without issue yesterday. No weird crap. No damage. And 1 day before I drive across country, much respect.
Bthnc
They ended up giving me a loaner because I asked them to check a couple of other issues and seems like they were backlogged a bit. As a side note, the two issues I was having was SiriusXM often not loading (I think this is a software issue but figured it didn’t hurt to mention) and cruise control sometimes not turning on. Steering wheel controls (only for CC) do nothing, as if the system is off. Only happened a couple of times. Fixes itself at some future start.
Aaron 21 Tahoe
What do they do for the restraint recall? Anything I should look for after it is completed? I don't want them to dick something and I miss it when I pick it up.
tomgilk
For my 2021 Z71 they just take the seat off via the velcro on the underside so there is nothing to damage really. Not sure what happened to the guy earlier in the thread, not proper training I imagine.
revengejr
Hi guys, so I have a 2021 Tahoe RST with 1,500 miles bought in February. I also had the SRS light come on around 1,200 miles, took it to the dealer for servicing and they found code B1A7A. Reset it and no issues until 1,500 miles. Yesterday, my wife noticed the visor lights not working and on a whim, I cycled the map lights and, viola, visor lights work again. Also notice now the SRS warning light is off. Reading everyone else's replies, has anyone else found a resolution for this? I am taking it back to chevy tomorrow morning for them to look at. Thanks!
revengejr
Just to update my last post here, I just got back from the dealer to look at this and in-fact this is a known issue from GM. I had them print it out for me. It's in their system as doc id #5651275 and #PIT5774. Apparently the cause "could be a logic lock with the A103 roof console" and according to their paperwork, "when the vehicle is checked for DTCs, there will be a current U1121 set in the BCM and B1A7A set in the restraints module." According to the correction section, "Engineering is currently working on releasing a fix" and "the PI will be updated at that time." I read that as a software glitch that needs to be corrected or that A103 module will need to be replaced. It's dated 9/14/20 so it not that old. I hope this helps others experiencing this weird issue.
CentralMT
OK, you guys are brilliant! I had code B1A7A on a 2021 Escalade Platinum Sport. Dealer scanned codes, couldn’t find any relevant bulletins and said to bring it back after our 1000 mile trip was over (with no airbags functioning). Read this thread on the first night of the trip, opened up the truck, power cycled the map lights and started the engine. The airbag light is now gone and everything back to normal. Thank you all! FWIW, a good symptom is that the passenger airbag info on the right side of the info grouping by the map lights wasn’t working and of course the SRS light was on with a notice…. Now it seems to be fixed, along with a couple of other bugs. Can’t believe the dealer couldn’t solve or even find the issue but one search on this site and everything seems to be solved. I will be back to report if I have any recurrence of the issue. Joined the forum just to thank you all who contributed.
General Fodder
