St. Louis
Just to give you a heads up, the bolts take a 21mm socket.
I kept the rear tires on, but did end up pulling the fender liner on the passenger side.
Did you R/R with the suspension loaded or hanging?
wjburken
Eastern Iowa
I put jack stands under the frame so the tires were off the ground and then put my jack under the pumpkin to load/unload the axle to align the bottom bolts to remove in install them.
It’s kind of a pain to snake a socket around all the evap stuff on the drivers side and the rear A/C lines on the passenger side when getting the top bolts out.
Jason in DLH
Cheeseburger and Fries
MN
First attempt at plasti dip...
And you need one of these spray can triggers if you do much spray can painting like me...
wjburken
Eastern Iowa
I don’t know why I don’t have one of those. I finally organized all my spray paint and I have about 30 cans left after I threw away the old ones. So I just ordered the damn trigger. :mad:
I have three of those trigger handles, for sure. Might have more.
My son used one just yesterday to paint a chair he built.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Anybody know what size socket for the oil pan bolts on the 5.3?
Drewphil
