2008 GMC Yukon Denali XL - (152,000 Miles)
Hi everyone. I am looking for any help possible in selecting a new suspension system for my Denali. I have been reading a lot of threads but not really finding what I need to make a good decision. I bought this ride one year ago and noticed that the compressor wasn't working so I replaced it, but have since noticed that that it is beginning to sound sick again. Evidently both of my rear air shocks are leaking so I think it is time to just replace the whole system. I have a couple of different paths I am considering.
- Keep stock height and replace air system with passive system. I want it to be a good ride and reasonably priced. Don't want the cheapest but I'm not looking to go crazy, this is my wife's daily driver with all the kids. Initial research found that Arnott and Strutmasters have fairly simple kits with autoride warning light fix.
- Are either of these a quality system?
- Strutmasters
- Arnott
- Other Recommendations???
- I don't often put a trailer on this ride, but if I do I know that without the auto leveling the back end is likely to sag. I am considering adding the Air Lift 1000 bags. Will this stiffen the ride too much that it may make for an uncomfortable ride? Will it make the back sit higher?
- If I want to add a lift what products should I seriously look at? I don't want to go too high.... somewhere in between 2 and 5".
- I know Rough Country has lift kits of 3.5", 5", and 7". Their notes state it doesn't work with AWD .... but in communicating with customer service they say it will work but the front drive lines need to be replaced with a double cardan driveshaft in order to eliminate driveline vibration.
- Are there any puck lifts out there that members have installed that they would recommend? Not really concerned about leveling, theres only 1" diffence from front to back currently.
- I've noticed some squeaking from the suspension. I suspect I may need to replace ball joints and control arms, however does anyone else have recommendations?
- Also, theres a little bit of high pitched squeal while driving through the neighborhood. Ideas? (I know, just turn up the radio and you won't hear it anymore)
