New upper control arm and an 18 mm ratchet wrench to get the nut off. Not much room there above the axle shaft to even slip a socket on.
Completely agree. I'd rather spend more and not have to change them every year. I used the OEM on my 07 and rarely had to change them in my 10 years of ownership so I'm sticking with itThe OEM ones cost a bit but the aftermarket ones break so easy. Did you order chrome ones or are you gonna CM?
I used my impact with a swivel attachment to get into the tighter spot. Came in handyNew upper control arm and an 18 mm ratchet wrench to get the nut off. Not much room there above the axle shaft to even slip a socket on.
Is that your standard PPV cluster? I didn’t realize they had the chrome rings around the gauges.
Honestly, I don't recall. They weren't GM. The hubs are Timken.Which end links did you use?
I'd leave it deactivated. My reasoning is that the lifters are held rigid by a pin that is retracted when AFM activates. If the pin never moves, the lifter can't collapse uncommanded unless a part physically breaks. If you turn on AFM, the pins may retract but not return to the "locked" position, leading to failure.
Read your post and did the same tonight. Thanks. I left the 2 sections where the brackets were as you can see. But much better looking.
I have that exact same work light.
Why yes, yes I do. I have used that one a few times- its called a "I gotta cut this damn thing and I cant use a power tool on accounta I got no room" sawzall.Yeah, but do you have that same Sawzall?
Damn, that Cali gas is expensive!Thirsty bishView attachment 259898
Mine runs that high until it gets up to temp
I didn't say it wasn'tZoom in on the pic, it was at operating temp
$3.19 for mid grade which isn't all that bad for around here a lot of places in California it's almost $4, I usually spend around $400 a month for gas give or take littleDamn, that Cali gas is expensive!
I filled up today too, 26 gallons of E85 for just under $50 ($1.84/gal)
I bought gas today for my Tahoe. Odometer show 14,717. May have to replace the tires sometime around May 2036. Last year, I found some gizzmo in the interior that I had never used before and had to look it up in the owner's manual. LOL
