616 miles on the odometer and our new 2021 Tahoe LT won't start!!!! P1029 error code
Fireman591
Fireman591
Michigan
UPDATE------------- Well today I took it to the dealer. They stated that the fuel pump assembly is going to be replaced. The bad news is they do not stock that pump so I am crossing my fingers for a speedy delivery of a fuel pump assembly. On top of that I was also informed that the 2021 Tahoes have a recall on them already. The oil cooler lines need to be inspected and replaced if need be. I was given a Chevy Traverse as a loaner so as soon as the Tahoe is fixed I will update if I get more information out of them.
Toasty
Yep. The oil cooler line recall has been out for some time. The oil cooler lines weren't being routed quite right on early builds. Depending on when yours was sold, surprised it wasn't handled before delivery.
Fireman591
Fireman591
Michigan
It might have been. Hopefully mine is just one of the investigations instead of a full blown reroute. I do know once she ran the Vin number it stated there was still an open recall on the vehicle. My vehicle was in the 8000 range as far as order off the line.
BourbonNcigars
Hope you get everything worked out as painlessly as possible from here on. And that you don't have any further issues. I know I'd be beyond upset if I was going through this with such an expensive and brand new vehicle.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
******* sucks Steve!!!!!!!!!! Hope it works out for the best?
Fireman591
Fireman591
Michigan
Thank you and no big deal. They will get it right. Minor issue compared to by brand new GMC Terrain back in 2010. It left the factory with a failed high pressure fuel pump seal. Every time the engine was shut off a few drops of fuel would drip into the crankcase. Over a 3000 mile span a few quarts got in there and sheared down the oil during the very important break in period. The upper part of the engine was ok due to the rings but the main bearings must have taken a beating. The best I could ever get MPG wise on the highway with that I4 engine was 20mpg. It was supposed to get 30. GMC would not replace the engine and I bailed on GM for the past decade. Hopefully they will stand behind their products this go around.
BourbonNcigars
To be honest, I get more and more doubtful about manufacturing quality (the sea I swim in) in almost any area as time goes by and we venture on toward the future. Labor issues, cost cutting, lack of proper training/protocols, etc. It's getting worse as people dig deeper for profit.
Hrocks
Sounds like the typical GM first model year blues. I had them a couple of times, most notably an Escalade when they changed to the GMT900 series in 2007. GM and Cadillac were not helpful at all. If not for the intervention of a buddy of mine that owned a Chevy dealership, I would have been screwed. As much as I'm jonsing for a C8 Corvette, there's no way on the planet I would buy a first model year from GM.
Toasty
Hrmm. I think it was actually a TSB for the dealer on dealer inventory rather than a full blown recall - depending on when yours was produced and sold, it might not actually have applied. (it was issued in July)\ https://gmauthority.com/blog/2020/0...The bulletin was issued last,2021 Chevy Tahoe
On our 900s the transmission has to be in neutral and the parking brake applied or our foot on the brake before we can set the transfer to neutral. Well, have the dealer demonstrate it to you both with the motor on and off and let us know.
Fireman591
Fireman591
Michigan
UPDATE------------------- The dealer called again today and stated no luck yet on the fuel pump control module. They opened a STAT case with the GM regional rep and they are aware of the issue. I asked if they were 100% sure if that module was the problem since the vehicle ran and drove fine after the event. She stated that the vehicle died when the tech was working on it and they were 100% sure it was the fuel pump control module because it failed the tests they put to it. I hope they are right but I was very happy to hear it died on them. Another plus was they are going to get us into a loaner Tahoe or Silverado pickup sometime this week instead of the Traverse they loaned us. i am so used to the size of the Tahoe that the Traverse seems like I am driving a car :) LOL
Fireman591
Fireman591
Michigan
Update----------- Went to the dealership again today to swap loaner vehicles. They gave me a brand new (7 miles on it) Silverado Z71 RST to drive until our Tahoe is repaired. The service rep stated the GM regional rep now has engineering involved in tracking down a module so hopefully it won't be to much longer. Driving a brand new pick up sure takes the sting out of not having our Tahoe. It will be a great chance to see what they are like to drive as daily drivers :) LOL
Fireman591
Fireman591
Michigan
This sucks. I hope they fix it right. It's so hard to schedule appointments and arrange for alternative transportation. It seems I always get stuck in a disgusting loaner with french fries stuck in the seats.
I lucked out. I swapped out the Traverse for a brand new Z71 RST with 7 miles on it. It will be our loaner until the vehicle is repaired :) Kudos to the Serra Auto Group for taking good care of their customer :)
Toasty
if it comes down to it, I wouldn't be surprised if one gets pulled off the line
Fireman591
Fireman591
Michigan
How did you get a STAT GM case? My Tahoe gave me carbon monoxide poisoning and I’m still waiting on a rep to get in touch with me 4 days later!!! Do you have a good contact #? Sorry about what’s happening. I’m about done with Tahoe’s.
YIKES!!!!!!! Sorry to hear that. I am just letting my dealer handle stuff. We buy a ton of vehicles from these folks so I am confident they will work hard to get things back to normal.
Tam Lebofsky
Well tonight I went to start our vehicle and it cranked for 10 seconds and stopped. I tried it again and it fired up after 7 or so seconds, ran like the timing was off and quit. Onstar found this on the online scan: ----------------------------------------The Engine and Transmission System is not performing as expected. An issue has been detected in the Fuel Management System used to maintain, control and monitor fuel consumption.---------------------- P1029 is the error code.
Needless to say it will be getting towed to a Chevy dealership Monday. I am not a happy camper but thank God it happened in our garage and not out on the road somewhere.
I will update this thread once I find some answers from the dealership.
Thank you for being the world's guinea pig and testing the brand new Tahoe so they can work the kinks out so when I buy one it should be good. Someone has to do it. Lol
Sent from my Lenovo TB-X705F using Tapatalk
drakon543
ha so much truth here and the reason i dont ever want to buy something brand new.
Fireman591
Fireman591
Michigan
Thank you. We all can't be cowards or there would never be a second model year :) LOL
Tam Lebofsky
Well I'm not so much a coward as I am a smart a$$. I have been there with my 07 Tahoe and that AFM crap was a nightmare. The valves tuck on one side of the head so they replaced just the bent valves and didn't want to touch the other side. Was without truck for 2 weeks. Got it back from dealer and a week later the other valves stuck. This time did it in a week. Got it back, self leveling air suspension went out. Finally sold it and bought an earlier Suburban before all that new tech. Haven't had a problem with it yet. But hey, like you said, you have a brand new Z71 to play with. I'm the salty one lol. Enjoy your new Tahoe when it's fixed. And after you work the kinks out and tell us all that may go wrong I may step up and get one then.
B520044
I was/am really worried about the reliability. The only reason why I went forward with the purchase was because the drive-train (seems) was the same. Same ol 5.3L and 10 speed transmission (With Fords help). I guess it's all the other 1000's of parts that can/will go wrong! LOL
So far that has been the case.
Escalade2007
