Just Fishing
Can't fix stupid
Rebuilt my 6l80e valve body, installed transgo regulator valve, tcc valves, etc...
Topped off with a new separator plate, sonnax non shrinking check balls, and sonnax end plugs.
Rebuilt the tcm pressure switches, only found one about to give up the ghost.
Sonnax seal installer tool was worth every penny.
Had the truck on jackstands with the nose in the air for a few days...
Everything back together and back on the ground.
Got the truck nice and hot, fluid up to temp and then did the trans relearn procedure...
While it was doing its thing, i noticed my oil pressure was real low.
Hp tuners said 24psi at idle...
Been hearing ticking from the non afm side of the engine lately...
Looks like I'm doing an oil pump pickup o-ring today!!!
Yay!
Yay!
