What octane does the owner's manual call for? If it calls for 87 and it pings then maybe you need to contact dealer and ask why it needs the higher octane to keep from pinging.
My 02 runs fine on the lower octane but I always use the middle octane, Chevron grade labeled "Plus". Performs great and has more additives that I feel help keep the fuel system clean.
Modern vehicles are computer controlled to adjust for fuel octane and other factors. As a result, the recommendation is now to follow the octane rating recommended in the Owner’s Manual. Likewise, some OEMs may recommend Tier 1 gasoline when available.
It is important to note that Gasoline for use in motor vehicles is strictly regulated by the EPA, and as a result, must meet certain minimum standards. The following is from the EPA web site:
The Clean Air Act requires EPA to regulate fuels and fuel additives for use in motor vehicle, motor vehicle engine, or nonroad engine or nonroad vehicle if such fuel, fuel additive or any emission products causes or contributes to air or water pollution that may endanger the public health or welfare. EPA must also address emission products of such fuel or fuel additives that may impair any emission control devices used on vehicles or engines to reduce harmful emissions.
Gasoline regulations are under 40 CFR Part 80 (“Regulation of Fuels and Fuel Additives”): subparts A (general provisions, applying to all 40 CFR Part 890 fuels programs), B (controls and prohibitions), C (oxygenated gasoline), D & E (reformulated gasoline), G (detergent gasoline program), H & O (gasoline sulfur) and J & L (gasoline toxics).
Hope you can get this resolved so you can finally get a good nights sleep.
Man....I thought I wasted one there.If only I had a decent pillow.
Ok finally got decent videos of this...you can clearly hear a new noise begin around 0:04, it cuts in and out on acceleration...
And here from about 0:04 to 0:09...
Ignore sound of my keys hitting the column in the vids. Truck performing otherwise fine.
Thanks.
I just hear wind and road noise and knocking and rubbing over the microphone in the second vid. I think I hear a metallic ringing in the first vid- is that it?
Got the same sound on my 18 5.3. Been there since day one. Goes away when warm. Now have 30k miles. Zero oil consumption. Afm turned off with tuneIts a clicking/tapping sound under load from driver side of engine. I don't know if this is related but here's the noise it makes on a cold start....
Not sure what to make of all this
