Bear77
South FL
IIRC it goes around the rim on the outside of them.
Ya there was a lot of water in there but I had just pressure washed it a couple days ago, just wondering if it takes any special kind of silicone because of the heat or not
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
yaa.. but can you believe they are discontinued fuuuck calling around for one if not then junk yard hunting I go....
Check the torque on those valley cover bolts while yer at it brah. Wouldn't even hurt to replace that gasket and the oil pressure sensor while you are that deep into it. Good job getting that bolt out ya lucky sumbish LOL.
that's what happens when you don't follow directions, 44 inch lbs not 44 ft lbs :oops: I was like ****** **** they can't go this tight, snap........
X2 on the Permatex Ultra Black. I've never done the dam thing. I just smear a decent layer on the underside of the circular flaps before snapping down the knock sensor harness.
Also, X2 on replacing the valley cover gasket while you're right there. Maybe even the oil pressure sensor and/or cam position sensor, or at least the gasket on the cam position sensor.
T
I think this guy has it in this vid. He has a bad ass torque wrench. Check around the 21 min mark. I don't have sound a work.
Thanks the bolts were all good at 18lbs, the m6 x 1.0 x 70 fit perfect, she fired right up and no immediate codes drove it a couple miles, seems ok, time will tell
Merch619
