Digging through my phone and found some pics...
This is the switch I plan to use for my exhaust volume control. I'm pleasantly surprised by how well it'll blend in with the rest of the dash. The color of the plastic is a near-perfect match and the bevel on the surround is more squared instead of the usual bulbous rounded edge:
I'll make up a filler panel to mock the headlight switch panel, but I'll see if starting off with a 4WD switch panel would be easier. I think if the arrows were a bit thinner/less bold, it'd look like a factory switch. Unfortunately, it's not lighted. I'll have it centered like so:
Just because I like the clean metal bits:
pwtr02ss
Tennessee
How she been treating you?
I put my stuff on hold until Casey gets healed up. I figured out that what I thought was lazy lifter trying to pump up, is actually and exhaust leak. I can't find the damn thing, and none of the bolts are broken.Its on the driver side. I'm hopeful its between the manifold and y-pipe. I ordered ARP manifold bolts and all the gaskets, just in case.
Been doin great! No ticking at startup, still running strong, and still loud! lol
At the moment, I'm questioning my fuel trims and calculated (no actual sensor) alcohol content. Gonna reset them somehow and see what happens. This and some trans tweaking has lead me to looking at HP Tuners, but that ain't gonna happen any time soon.
Been busy with work and more important projects so the exhaust revamp is still on hold.
Did you order your other parts- cam, lifters, etc.?
pwtr02ss
Tennessee
Awesome, great to hear!
I have HP tuners. I bought it back in 2011 when I did the ls swap on the 74. Its a great tool to have. I haven't gotten very good at "tuning" with it, but the basic shit (reset fuel trims, turn off DOD, adjust shift points and torque management) you can do has been great.
Yes, I have everything (cam, lifters, springs, H3 mounts, water pump, oil pump, timing set, all the bolts and gaskets, gears, dod delete valley cover, oxygen sensors, plugs, belts, hoses, the bolt to plug off the bypass thing, stall, etc), I'm just need to buy the transmission rebuild parts and a few more hoses, I think. The truck has been sitting for almost 2 months and I decided Id rather drive it to work (100 mile round trip daily) than the 355k mile s10. So, I started investigation the noise. Hopefully I can get the exhaust leak fixed and drive it until I can get some help getting the thing apart , and that ticking lifter doesn't fail, lol.
Your build thread gave me all the part numbers I needed, lol
I'm glad my documenting efforts weren't in vain!
I have an 08 ** as well. How do you like those headers so far?
No complaints! I can't speak for any specific power gains since I did a cam and other mods during the time I installed them. After seeing the factory LT4 (wet sump) manifolds, I'd have to say there is proof to the tri-y design. I can say that they're not as "noisy" as most other headers I've heard. They're fairly thick gauge steel (14g, I believe) and ceramic coated. Supposed to have three coats on the inside and four or five on the outside. Longtubes tend to "ping" at the collectors, and thinner gauge and/or uncoated steel makes this louder. These don't have that pinging, maybe the tri-Y design helps to reduce this as well. The build quality is great and they bolted right up with no fitment problems. Flanges are thick and flat. The Y-pipe doesn't appear to be ceramic coated and fitting it required some modification, as I outlined here. Other than that, just know that cats are effective mufflers and without them, you'll hear it!
Yesterday, I removed the core from the port on the fuel rail, slipped a piece of 3/8" (or smaller?) fuel hose over it and turned the key on for about half a second to collect a test sample to see what my alcohol content was. My scan tool showed it to be 22-23%, but the tester shows it to be at least 85% but looks a little higher. So, I don't know what is making the Tahoe calculate it so low. I filled up with 93 at Texaco (pretty sure it's E10, but may be E0). After about 15 or so miles, I'm showing a calculated alcohol content of 3%. I don't know...
Also, my Long Term Fuel Trims are now about where they should be. Before, they were reading something like +14 and +9 (Banks 1 and 2 respectively) or maybe it was 9 and 14. Anyway, they're now around -3 and -4 and upwards of 0.
Correction: I didn't let the test fuel sit long enough. It settled out to show it was 65% alcohol:
A little more than what I was expecting, but also far more than what my Tahoe calculated it to be. To me, it seems like a waste to run it if it's only gonna adjust for 22% alcohol even though it's actually almost three times that.
What scanner showed after filling up with Texaco 93 (either E10 or E0- I'll try to remember to confirm next time I pass there):
...And the fuel trims:
Spent about 4 hours under it this afternoon trying to figure out how I'm gonna do my crazy ass exhaust. Well, about 2 hours of that time was working on the valve. I unbolted the motor drive from it and found that one of the butterflies was really dragging near and at the fully closed position. Used my Dremel to clearance the metal and got it operating about 99% freely. The motor drive must be a torque monster cuz it moved through that interference with ease. I know it'll be fine after some exhaust buildup. I'll just have to remember to cycle it a few times to keep it clean. That shouldn't be a problem, though. :D
I made cardboard templates of each of the mufflers to figure out placement and orientation. The smaller one I'm currently running is a centered/offset configuration, the long one I'll be adding is centered/centered. I was trying to determine which one should go first and how it and the valve will be clocked. It looks like it's gonna come down to me modifying the cross member for the extra space. That cross member isn't really structural, but I'll still reinforce it after modifying it.
img_2868-jpg.255848
Yes, I'm still working on that damned mower... Sometimes.
img_2870-jpg.255849
So far, I'm thinking this is a winner. Put the bigger one first and angle it and the valve as pictured so that I can tuck it up as high as possible with nothing extending below the frame rails with about 1/2" to spare. The second muffler will be clocked the same. The 3" straight pipe will run parallel. It will be on the ground/far side of the system so the mufflers will act as a sound barrier between it and the floor of the cabin. They will merge together right at the arch that goes over the axle.
I also tested out the DPDT rocker switch on the valve. I'll do all the wiring at the switch so I'll only have to run two wires to the switch (12V+ and ground) and then two wires (+ and -) from the switch down to the valve to have bi-directional control.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Thats odd. Will be watching to see what you lean. I wonder/suspect that it still adjusts the spark advance further due to less knock to too. Wouldn’t the fuel trims balance out over time?
It's supposed to adjust the injector duty cycle and timing accordingly. E85 has about 27% less energy than straight gasoline, so it takes about 27% more E85 than E0 to operate. My MPG on 93 is around 22 and it drops to around 16 on E85, which is a 27% loss, so that math works out. Yes, since ethanol has a higher octane rating (north of 100 for E85), the timing is advanced. These engines are rated at something like +11HP/13TQ when running E85, and that's why I was running it.
Before this fill-up with the 93, my trims were staying around 9-13ish, which indicates lean. So I'm wondering if, since it calculated the content to be only 22-23%, it didn't open up the IDC to get enough fuel into it and that's what made the trims lean. I still need to find out how it calculates the content in the first place. It shouldn't run lean because the O2 sensors would indicate such and the PCM would adjust. Also, I learned that idling will throw off the trims, and I was doing lots of idling when playing with my scanner to find them numbers.
HiHoeSilver
Away!
Chicago
Do you know if you have the actual sensor or the "virtual" sensor? I think it happened in 05, but not 100% sure.
Virtual. Yeah, from what I gather, they switched to virtual sometime during the GMT800 era.
I've been doing some reading and found that the calculations can be thrown off by lots of short trips or running higher than 10% alcohol during the calibration/relearn phase. I don't have a way to initiate a relearn but I'm wondering if resetting the PCM would do it. To reset the PCM in my older trucks, I would pull the PCM fuse while it was running. It'd have to relearn idle and all that. I'll have to look this up since I currently have a full tank of 93 that's possibly E0 and plenty of cruising distance around me.
@iamdub
Here's the South Main Auto reset on a 2012, not sure it can be done with yours. He resets it around 4:30.
Thanks, but I don't have a Tech2 :(
However, that did tell me that the calculated alcohol content "overrides" what the PCM adjusts for based off the O2 sensor.
BadDaddy2003
