I do have a transfer case, it's been 30-40k miles since its last service.
Don't laugh, do we have a front and rear differential? It just rear. I presume since I have 4wd I'd have both
Yep. Does it do it in 4WD too?
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Not gonna lie, I'm not sure. I can check when I get home, I'm currently violating social distance rules in an amusement park.
It seems like it catches it when it's close to shifting or downshifting and then I accelerate and it almost skips or has a slip when trying to get to the next gear.
Would it possibly be the differential? Would you feel the differential if something was off?
I think I know what your talking about. it's a weird shift like you depressed the accelerator right as it shifted from 1st to 2nd and it does this long soft shift. I have that happen once in a while.
CHOO CHOO
BackPagePhil
Manheim, Pa
My last post I meant to say I figured I had both front and rear. I definitely don't hear or feel a grinding. I'll check the fluid with the YELLOW handle when I get home. Does it need to be cool? Lighter red is good, dark is bad correct?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Red handle! :eek:o_O
check it on a level surface, hot (after a drive) in park engine running, fluid level should be at the hot mark on in between hot/cold marks, pinkish-red like the other meat is better
CHOO CHOO
BackPagePhil
Manheim, Pa
Handle shows up yellow just an fyi [emoji6]
Merch619
