Wrong pvc might be the reason you got alot of oil dripping out of the intake.
Imo, hose length doesn't really matter. You should be fine. What alot of guys do, including myself--is to put some steel scrubbing wool in addition to the catch can filter. It helps to catch more oil vapors.Btw instructions say to trim to fit, then zip tie together, but I wanted less kinks/angles in the hose, plus slightly longer hose would allow me to easier move it out of the way without needing to remove it if working on something else.
Does hose length matter in this case?
