lowh07
@lowh07 How do those headlights perform and how's the light output?
aa345dc1-2338-4410-884c-31fecc606711-jpeg.249951
Halogens suck in projector housings so I switched to HIDs. The pattern kinda sucks and I’ve been liking the stock type more lately. I’ll be retrofitting some stocks at some point.
Geoffsfas10
St. Louis
originally I was going to get those lights to do my retrofit. Kinda wish I had anyway, but oh well.
Watching for the results of your diode test.
Ok it works. I got some big Schotky blocking diodes off Amazon, cut the wire in half and put one in the middle. Now the current can only flow one direction so the headlight relay turns on the fog light relay but the fog light relay can’t turn on the headlight relay. Having it above the fuse box isn’t the cleanest but I’m not going to pull the fuse box to install it underneath until it’s been in awhile and I know it’s safe. I figure if it’s gonna get hot I want to see it and not have it hiding. Once I’m sure I’ll probably pull the fuse box and wire it in permanent. So now the fogs are on with low or high beam automatically and I can turn the fogs on by themselves or with the park lights or with the headlights.
St. Louis
Keep us updated on the heat issue!
Lead free solder on these old rigs
if it was using leaded solder then it will not have an issue
BS buddy. Solder used in our rigs (and all electronics) has been 60% tin and 40% lead for the last several decades at least. It still is if you go buy some. Well, close to that. They call it 60/40 but there’s a small percentage that’s flux.
PG01
Up here to the right
Brents World ... excellent, party on Garth.....lmfao
ASG-MikeS
