Looking for 2012 - 2014 Tahoe LTZ - Opinions Needed
cmatt
I'm looking for a Tahoe LTZ 4WD and wanted some opinions about factory options. Specifically, HD trailering, 2nd row captains chairs and sunroof.
Finding one with all those would be ideal, but seems to be a unicorn. I've found some with the HD trailering (additional fluid coolers, 3.42 gears & factory controller) but no sunroof or captain seats and vice versa. That said, I realize it's largely user preference, but would like to hear your opinions.
BTW buying a vehicle is still very frustrating.
the captains chairs can be swapped for the bench seat at a later time if that helps narrow down the search, they just have to be from the same wheel base tahoe/yukon/escalade, the ones from a suburban or xl, esv will not fit
also try expanding your search area some of us have found what we wanted farther away flew in and drove em home or had them transported.
Texas seems to have the most trucks out of the western states anyway
St. Louis
It might be easier to find what you want but without the brake controller. An aftermarket controller can be added rather easily
PPV12HOE
NC
I'd buy one with the sunroof you want... brake controllers and captains chairs can be added easily after the fact... adding a sunroof is a pain in the a**...
C
cmatt
Thanks for the responses. Good to know on the captains chairs. The main thing on the HD trailering is the 3.42 gears. I can certainly add the other items. If I find one with a sunroof, that would be great, but I won't be cutting holes in the roof.
I've expanded my search to include Suburbans as well.
C
cmatt
@gooffeyguy Looking at the signature pic of your Denali, are those the original door moldings? It looks like the Escalade style? Also, did you swap on painted mirror caps?
St. Louis
Yes, factory moldings and mirror caps.
I think only the Escalades and LTZ models came with chrome mirrors
intheburbs
SE MI
If you're looking for a very specific combination of options, there are several websites that allow you to search for them through the used vehicle inventories. I've found four used vehicles (all purchased in the $20k-$25k range) over the last 5 years using Autotrader. Great site. Customized search for options, model years, mileage, distance, price, and you can set email alerts for when new listings pop up that meet your criteria.
The more specific your search parameters, the larger your search radius needs to be. When I was looking for a true unicorn, my Suburban 2500, I was doing a national search. Try finding a 2500 with the 3LT trim (no LTZ available). Very rare vehicle.
the problem is these idiots will list a vehicle and totally overlook those details so it becomes a very time consuming process even when I was shopping for mine I had mistakenly come to the conclusion that all Denalis come with a sunroof, hah nope although I would say 99.9% of them do. you will find a lot of omissions or errors in listings so I resorted to using a good vin decoder that would give me the specs I wanted
this is the best vin decoder I could find that is free, it will let you decode a few then it will think you are a robot and start requesting you to confirm you are a human with pictograms but the easiest work around for that is to do the "audio" confirmation, click the speaker and just type in the key word it plays much easier and faster than clicking a bunch of boxes
https://chevroletforum.com/forum/vindecoder.php?vin=1GCUKREC2FF201830
C
cmatt
Thanks for the responses. I’ve found a 2012 Suburban LTZ 4wd. Hopefully the dealer and I can come to terms. It’s interesting, the 3.42 gears, trans & oil coolers are present, but not the factory trailer brake controller. I know an aftermarket one can be added, but I’m curious what’s involved with the factory one.
Anything I should keep an eye out for while inspecting it?
these trucks come pre-wired for a aftermarket controller you just have to connect the harness under the kickpanel and a couple wires to the fuse box that are also already present and maybe a fuse that is required but that's about it
STORMIN08
On the road is my 2013 LTZ 4wd, selectable transfer case (has 2wd like Z71's),leather and all power, touchscreen nav, Quad seating, 3rd row and i do believe it is 3.42 gears...moonroof, dual rooftop dvd, 3rd row seating, power flip 2nd...everything works as should, runs great and i have owned since 37,000 miles (2016 ish)...regular services be myself, and new front Arms, joints and tires. all stock as it left GM.
it is my wifes daily and we are hunting a new version as she road trips regularly. Private party book is near 18K...
make me an offer, it will be traveling near the St. Louis, Mo area next week...from SW Lousiana.
C
cmatt
PM'd
scottd
