2015 Tahoe LTZ Towing Package Question
Jason101
Hello,
First post here. I've been reading through some older threads and couldn't find a solid answer.
I'm considering purchasing a certified used 2015 Tahoe LTZ with 30,000 miles and need the Max Trailering Package. I found one local to me that has this, but I have been reading some some Tahoe's have a self-leveling suspension that levels itself once you hook up your trailer. I think I've seen people mention this as RPO code Z85, but the Tahoe I'm looking at does not have that code. It does have all the codes for the Trailering Package:
  • MAX TRAILERING PACKAGE (Includes (GU6) 3.42 rear axle ratio and (JL1) Trailer brake controller. 4WD models also includes (NQH) 2-speed active Transfer case.) (NHT)
  • REAR AXLE, 3.42 RATIO (Included and only available with (NHT) Maximum Trailering Package or (Z71) Off-Road Package.) (GU6)
  • TRAILER BRAKE CONTROLLER, INTEGRATED (Included and only available with (NHT) Maximum Trailering Package.) (JL1)
  • TRANSFER CASE, ACTIVE, 2-SPEED ELECTRONIC AUTOTRAC with rotary controls, includes neutral position for dinghy towing (Requires 4WD models. Included with (NHT) Maximum Trailering Package and (Z71) Off-Road Package.) (NQH)
Will the 2015 with the NHT have self-leveling?
My other concern is that it comes factory equiped with 22" tires
  • TIRES, P285/45R22 ALL-SEASON BLACKWALL (Included and only available with (RPT) 22" x 9" 6-spoke chrome multi-featured design wheels or one of the 22" LPO wheels.) (QST)
I thought I read somewhere (maybe not on here) that by having 22" wheels, that alone reduces your maximum towing capacity. Is this true?
I have the full list of RPO codes from the glovebox and don't see any that talk about self-leveling suspension.
I plan to tow a 4,500 pound camping trailer, but would like room to grow.
Thanks
Tahoe14
Central Fl
You have it with the MRC and Max Trailering Package and the 22s do not diminish your towing capability.
RedAggie03
Houston, TX
I'm not sure you are correct. On Chevy's accessory site the 22's do say they are not compatible with max towing...
J
Jason101
Red
Thanks. I'm still trying to learn my RPO codes and acronyms. What does "MRC" mean?
Maybe that's where I read it. I think they just slightly reduce your capacity by 400lbs or so and therefore you are not "max". That would be okay, but I wanted to see if anyone knew based on experience.
Tahoe14
Central Fl
For towing capacity refer to the Tire and Loading Information Label located on the B pillar, Drivers side. Also refer to your owners manual.
You can have the Max Trailering Package with different suspension options. ZW7 is simply shocks, the Z55 and other with "G65?" are self-leveling but not necessary.
Older publications for early GMT900 mentioned a loss of towing capacity with 22" wheels, not anymore. Tires have gotten stronger since then I guess.
J
Jason101
I haven't seen these RPO codes on any build sheet I have seen. The only suspension information I have seen is within the NHT package and "Z95 - Magnetic Ride Control Suspension Package" Does tge MRC package mean it is auto-leveling?
The only G codes I have are GBA (Black), GU6 (Rear Axle 3.42 Ratio), G80 (Auto Locking Rear Differential)
If I remember right, Z-55 had the companion G-code for the leveling feature. Z95 also leveled. It's not needed for towing though. The NHT alone will do the trick.
I have the K5L and all the other goodies on my older truck but with the plain jane ZW7 suspension.
J
Jason101
Thanks. I just don't want the rear to sag and make the front light which is why I was asking about the self leveling feature. I couldn't tell what suspension is included in the NHT
That can still happen with heavy tongue weights, just put in some Air Lift Springs (bags). I do not believe the NHT includes a suspension option, it can come with whatever someone wants. At least that is how GMT900 was.
Kpwweb
From the 2016 Order Guide (which I can't imagine is that much different), Max Trailering (NHT) on an LTZ includes:
4WD models also include (NQH) 2-speed active Transfer case.
The LTZ also includes:
Z95 Suspension Package, Magnetic Ride Control, road sensing
electronically controlled shock absorbers
I have not seen a Z95 that didn't have the air shocks in the back... You could always have the dealer (or you) take a picture under the back and see.
Z85 is ONLY available on an LT with NQH:
Z85 Suspension Package, Standard, increased capacity, Premium Smooth
Ride with Air leveler
1 - Included and only available with (NHT) Maximum Trailering Package.
RedAggie03
Houston, TX
Yeah, I have the Z85 package with my NHT on my 2018 LS... Not sure how the 2015 was though. You can see an air hose connected to the rear shocks though.
bldn10
Memphis
FWIW on my '02 I have Autoride, which is RPO Z55, and separately, G69 Level Control.
KATfishing
I have auto-level on my Yukon Denali and every Tahoe LTZ I've seen has it... That aside because others have mentioned that it's possible the one you are looking at may not... couldn't you just do a visual check on the vehicle for air shocks and a compressor? Or, have another adult sit on the rear bumper while you start the vehicle. After a few seconds, you should hear the compressor kick on to level the vehicle... It's very noticeable, especially with the windows rolled down. I would be VERY surprised if a Tahoe LTZ with towing package wasn't equipped with auto-leveling.
Capybarbro
