Ride height: How high/low sit your truck?
Big Mama
Virginia
What trouble did you have with your wheels? If it’s rubbing I’d be surprised if an 8” wheel caused that but my vehicle isn’t lifted.
M123
M123
Viking
Sweden
Sorry for late reply, I don't see in alert new post. Must look at the settings. :)
I now my English are a bit bad. :D My new wheelse did get my car limp worse then a drunken sailor with a wooden bone, so did have to return them.
Did order them here online in Sweden so did get many problems down the road, one rim was a total mess, not anything that hade happen after it was painted because it was flawless in the paint. The rim was not round and was 10 mm larger on a half turn on the diameter, and the inner side did wobble crazy.
Sadly now my car stand with new tires on my original worn and ugly original wheels.
Did get a very big interest of the PPV wheels now instead after looking in @Tonyrodz thread with his gorgeous PPV wheels, and original are original and aftermarket are aftermarket, I at least always run in problems with aftermarket parts.
Sorry for long post. :D
Edit: The original wheels don't have a ugly design but are in very poor condition...
Big Mama
Virginia
Gotcha. Is there a powder coating shop near you? That’d be the least expensive and you can choose the finish.
M123
M123
Viking
Sweden
Yeah my work do have powder coating at a other facility we have so think if I need it they can help me out. :)
bigdog9191999
sw michigan
I will have to do some measuring on my hoe, mine had the self leveling ( nivomat style) but one was ruined in the accident that made me get the truck, I swapped the rear axle, and springs from my z71 avalanche ( as I had read the stock ones where soft with the nivomat setup) and it looked like a racoon with its haunches in the air. so I cranked the bars to net about an inch or so in the front and it is much better but I don't know what it was supposed to be ( I could not measure the rear with the nivomat pumped up as it was not drivable/broken)
M123
M123
Viking
Sweden
@bigdog9191999
Thanks for your contribution to the thread. :)
Would be amazing if you did some measuring on your truck, always fun to compare here what makes a certain height. :)
Thanks.
bigdog9191999
sw michigan
Ok, so as stated I have the front cranked about 1-1 1/2 inches and stock ( far as I am aware) avalanche Z71 springs and standard shocks.
35 1/5 front and 38 1/2 rear
I would guess at rest without the rear pumped up from driving that it was about 34-34 1/2 front and rear prior.
And here is a pic that I just did, well because I can.
Top is current, cranked with 265/70/17 ( wheels off my avy, because I had a blowout with the duratracs below)
Center is just after the axle/spring swap with 264/75/16 duratracs, so stock front and the obviously taller springs rear.
Bottom is stock with 235/85/16 winter force that was on it when I got it.
Again I don't know how it would have sat after driven as it Wes damaged and not driveable.
BG1988
Hi.
I am a bit curious what you guys have for measurement from the ground to top centrum of the wheel well on the fenders, both front and rear. Hope I do make any sense and point out the right name for it. :)
Anyway I would be great if you post picture here of your truck and list the suspension and your wheel setup.
Height:
Springs/Shocks:
Keys:
Wheels:
Tires:
View media item 28310
Every contribution are appreciated greatly. :)
factory drop same as the PPV but enhanced Aero Package
bigdog9191999
sw michigan
And because I had the tape in my hand and can here is my 02 2500 burb 8.1 with stock 245/75/16 at the edge of the fender flair
34 1/2-35 front. And about 38 1/2 rear
And the wife's 03 Denali stock with 285/70/17's
35 front 36 1/2-37 rear
M123
M123
Viking
Sweden
@bigdog9191999
Wow what a work you did put in to this subject, I really appreciate your amazing effort. :) This will absolutely be helpful for not just me how things add up but for more people that have interest in this.
Million thanks for you time and pictures. :)
abruck
