My Z71 seems lower than it should
Dustin Jackson
Dustin Jackson
Great job and looks good. How does it handle and the steering and suspension feel is good?
@PNW VietVet Much better, replacing the rear lowering kit was a huge improvement in itself and now I can take dips and speed bumps without worrying about bottoming out. I am really happy with how it turned out.
GMT800 2005 Tahoe Z71
Navy Supporting Member
The main thing is that you like it. That's all that counts afterall, except if you are married and or have a significant other and then they have last say.
Dustin Jackson
Dustin Jackson
X2 looks great, saved cash, got tools, gained confidence. Sounds like a home run to me. Did you get it aligned yet?
@Big Mama I haven't aligned it yet, I am debating on whether I should get wheel spacers first. Now that I have raised the Tahoe it looks kinda top heavy I want to push the wheels out to widen the stance. I am having a problem finding 2 inch hubcentric wheel spacers that aren't $200.
Dustin Jackson
Dustin Jackson
@PNW VietVet Hopefully this helps
20200527_124935.jpg 20200527_124927.jpg 20200527_121451.jpg 20200527_121512.jpg
I would go with a bigger/taller tire before I would use spacers. I am not a fan of spacers at all. Others here use them and like them but I will not be in that club.
Dustin Jackson
Dustin Jackson
@PNW VietVet I understand and I usually feel the same way but I really like the way these wheels look on my truck and I'm out of truck spending money, plus I can't think of any wheels that I could get and keep the same theme with the white and chrome. Down the road I was going to get larger AT tires to go on them to give more cushion and capability when driving off pavement.
That being said I was planning on driving without an alignment for a couple weeks until I can decide on wheel spacers or not, is 2 weeks enough time to destroy my tires?
Depends on how far out the alignment is as to damage done to tires. If it drives straight and steering wheel is fairly centered and the air pressure is good, you will likely be ok but watch for any wear, on a daily basis. I am not a fan of the spacers but I am not saying they are unsafe. In your case I would do the spacers and wait on the same type wheel and new tires and get new wheels then if wanted to.
That's not toooooooooooooooooooooooo much overkilll, is it! Good thing he had a locker so they all would turn at the same time.
So, the dog is sitting there going WTF Rover! :hitit:
I was gonna suggest spacers but figured you'd ask or just get them if they were even an idea in your mind. I wanted spacers on mine for the same reason- it looked too narrow for the height. I lifted mine 2" front, 1" rear and installed 1.5" hub-centric spacers. I've since lowered it and the spacers are now on my brother's Sierra Z71. I had very minimal rubbing at full lock with the 1.5" and OEM size tires. 2" would rub even harder, but with yours being a little higher, it may even out and barely rub.
These are what I had: https://www.amazon.com/gp/product/B01GQECY16/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I run my Tahoe hard and my brother's no more gentle with his truck, pulls trailers, etc. Never a problem. All That was needed was to trim the unthreaded tips off the lug studs. Also, I would've preferred 2" for the rear to even out the track width with the front. But, two different sizes of spacers was more expensive than four of the same size and I was just doing it for a quick and cheap change of appearance.
Dustin Jackson
Dustin Jackson
@iamdub I have heard that you need to get spacers that are at least 1.75 inches thick or you will have to cut the wheel studs on the truck, that is why I was going for 2 inches. I would prefer to get these 1.5 inchers if they will fit. Will I run into any problems down the road as far as installing other wheels because of cutting the tips off my wheel studs?
Not at all. There's about 3/8" of unthreaded and rounded-off tip and well as a little bit of threaded area protruding from the lug nut when they're tightened. You're just cutting off the unthreaded excess. If you get the 2" ones for the rear, you'll only have to trim the front ones, if you wanna factor in labor in your decision to splurge on them.
Lemme see if I can dig up some pics from my build thread...
Dustin Jackson
Dustin Jackson
@iamdub Thank you, I have ordered them already. I am finishing up my truck with brakes, sway bar links, and wheel spacers next weekend. And then an alignment.
Big Mama
Virginia
I had adapters to fit a set of Ford lug pattern wheels for a couple of years that were 2” until I could afford new wheels. I got them on eBay seller mywheelspacers I’m not sure if he has a website with that name but they were under $100 a few years back.
JasonW4141
