Agreed. Sux! Sorry buddy.Can’t like
Moar pics for you ball busters.
View attachment 248346 View attachment 248347 View attachment 248348 View attachment 248349
I concur. I am going with this theory and will start all over again. Just to eliminate that out of the question because I really believe everything thing else is good. That’s the only doubt I have right now is not replacing those. Also found this @ 2:47, cause #2.
Just screwed now until Tuesday to try and track down new parts. Means I have to call out of work too now. And hopefully get this fixed.![]()
You should be ok reusing the intake manifold.Can I reuse the intake gaskets or do I have to buy them again too? $$$$$$
Hopefully the dorman holds up
Looks like hot chocolate!I got rid of 2 more faults for the PCM today. The previous owner decided to remove 3 of the 4 O2 sensors srating that they were bad just for me to have to order replacements and replace the FUSE that was causing the fault for the rear O2 heaters...
Hosed it off today and started scrubbing the carpets clean. 5 buckets of mud later and the area under the 3rd row is finally clean. This thing is going to take a while.View attachment 248573 View attachment 248574 View attachment 248575
This why floor mat's are in mine, between mother nature and kids spilling soda and juice and me spilling coffee ughI got rid of 2 more faults for the PCM today. The previous owner decided to remove 3 of the 4 O2 sensors srating that they were bad just for me to have to order replacements and replace the FUSE that was causing the fault for the rear O2 heaters...
So what do you think the reason you were getting all the codes?She’s running normal, no codes, cleared the codes. No misfiring.
Fingers crossed! Thanks for your help and putting up with my rants!
That’s awesome, and you got it done before work tomorrow? Was that a new valley pan with solenoids and gasket? I’m just glad I’ve never dealt with AFM. I would rip that every part of that shit out, run a good cam, and never look back.She’s running normal, no codes, cleared the codes. No misfiring.
nice!, did you use led's or go with some lights from the nbs's?View attachment 248578 View attachment 248579 View attachment 248580 I got the interior of my Silverado back in, added footwell lights, fixed the AC and airbag. No more warning lights.
