Shadowz Edge
Who doesn't like a bubble butt??
And I like bubble butts and can not lie.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Wish it was mine. Before I die I want to own at least 5 of the barn door models. Did they ever make a Z71 barn door Tahoe model from 2000 to 2006?
Shadowz Edge
I’ll show you mine!
Wish I could orient the pic properly lol
Take the photo that's in your phone...
Tap on edit (should look like a pen or pencil) ...
Then tap on Rotate ( should look like a circular arrow) ...
Tap Rotate until you get the desired look ...
Then tap "Save"...
And then your done!
I hope this helps you out in some small way. :)
Edit: changed the 2nd "edit" in the post to "Rotate" (whoops)
Then tap "Save"...
And then your done!
Samsung phone?
Shadowz Edge
Pulled my passenger door off. Attempt #12 at getting it to shut right. Discovered my speakers were getting wet. Love this truck
I still have yet to pull my front doors to replace all the hinges since both doors are sagging. I'm not looking forward to that repair either. LOL
Shadowz Edge
Check it out what the heck is going on with my door
I've never had good dealings with Dorman so I'm going to say possibly a bad lock mechanism on their part. I would locate a new or even a used ACDelco original from a yard and see if that solves the issue.
There's also the possibility that even if the lock is good the door frame up at the top may be bowed in towards the body causing it to not be fully closed without extra force.
I agree with the Dorman conclusion. Try for a used oem if possible. I had the exact same problem with my 95 Blazer. Did the door hinges and got a used oem latch. Fixed it. Would close tight on the first try.
wwiizz
