Wet Concrete From Transmission Extension Housing
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yea, that stain/puddle on the ground looks oily and not just water wet. Plus it looks like trans fluid getting ready to drop off that u-joint cup on the driveline.
I can’t for the life of me tell from those pictures what the fluid is. If I zoom in at the bottom of the driveway pic it looks like water but the reflection above looks slightly pink. And there’s a drop coming off the u joint but nothing coming out of the tail shaft or seal so it might be dripping from above. What color is the fluid on the driveway Scott? Does it look like trans fluid or not?
I see spray marks above but not on the exhaust, probably burned off. Fluid does look too dark for trans unless his is dirty of just the magic of cameras in dark places.
YukonCrazy
YukonCrazy
Raleigh, NC
Looks like it's time for a new one. Funny thing, that looks like the seal on the back of my transfer case. If I'm reading the books right, yours should look completely different. I'm coming up with 8677268 for yours and installed with J-21426 but could be wrong.
Is that the part number for the transmission extension housing or the seal? The trans extension housing I purchased came with the seal already so maybe I have the wrong trans extension housing?
Anyway to determine the trans extension housing is correct other than with the dealer?
I believe you should be looking at the output shaft seal, the rear seal on the trans itself. That much fluid means to me that your rear seal is leaking pretty good and filling the extension housing up and then leaking out the back of it. It should only get a small amount of fluid in it. Every time I have pulled my trans and separated the extension housing there has only been a small amount of fluid in the extension housing.
YukonCrazy
YukonCrazy
Raleigh, NC
I am guessing replacing the output shaft seal is quite a task and likely pretty expensive to get it done by a mechanic?
I have never done one but I don’t think it’s too hard. Somebody that’s done one will chime in hopefully. Pretty sure it’s like an axle seal and those are easy.
If I am not mistaken, maybe Rockola1971 can chime in, that is the output shaft seal that the driveshaft is slipped in to in the pic. That design has the bellows cover at the end to help protect the yoke spline surface. You may have a output shaft bushing that is bad but you did say you replaced the extension housing and that would have come with the bushing and seal. The one here is the other design seal without the bellows: https://www.rockauto.com/en/moreinfo.php?pk=9483168&cc=1441039&jsn=2322
I have replaced a lot of those bushings and seals. The seal is a piece of cake but again when installing the seal use a seal driver if you can. The bushing replacement is a whole other story. It is not hard if you have the special removal tool and the install tool. If you used other tools than that I would bet you would damage the housing just removing the bushing. I am talking about replacing the bushing with the housing still on the transmission. Is easier if the housing is removed.
That bushing needs the fluid around it to lube it during use. I am no trans specialist but there has to be a flow of fluid to it to do that and of course the seal is to keep it all in.
And I’m not sure about that extension housing, the only one I’ve worked on is mine and it’s AWD so the extension doesn’t have that kind of a seal, it has a big o-ring that seals the extension to the trans and a regular gasket between the extension and the transfer case. The output shaft seal is at the rear of the trans before the extension. But it seems to me the seal at the output shaft on both transmissions should be the same, or do they move that seal to the back of the extension on a 2WD?
Exactly Mark. The 2wd has the seal at the end of the housing. That is what was throwing me when you made your earlier post. I know that the 4wd or AWD would be different of course but since I am no trans specialist I looked for the seal for it and saw that bushing and knew at that point it was like I have changed out before. Usually when a relatively new seal like that starts to lek that quick it is because of driveshaft yoke being dry when shoved in there, or a nick on the seal from something else during install but he said he replaced the whole extension housing so the seal was already new and installed. Or the yoke itself is bad/damaged or out of balance or crap, just about anything else like bad luck.
The seal. I might be wrong too. You can ask Rene and or put your VIN in at ACDelco's website and look it up to make sure.
https://parts-catalog.acdelco.com/catalog/catalog_search.php
Have not read page 4 yet but Rocket Man's comments make sense too.
PG01
Up here to the right
@PNW VietVet
when you want to tag someone put the @ symbol before their name.... just a friendly fyi
btw im going with seal and driveshaft out of balance.... my 01 went through a few seals (output shaft seal on transfer case...pretty much same thing as end of the trans on a 2wd) until i had an aha moment as to why, yanked the shaft sent it out to be balanced and viola...
ps @YukonCrazy .... i knew what you meant by wet cement.... first post you said drip out of trans.... ;)
YukonCrazy
YukonCrazy
Raleigh, NC
What brand was the new extension housing @YukonCrazy ? I’m wondering if it came with a cheap seal of it was aftermarket. Might just buy a new ACDelco seal and install it in that extension.
Pretty sure it was ACDelco.
Pretty sure it was an ACDelco. I will see if I can get a pic of the number on it. Also ran my VIN through the ac delco parts catalog and came up with the same part.
Auto Trans Extension Housing
Part Number: 24241496
Product Notes:
All; VIN: 0, RWD, Auto Trans, Eng Code: LMG, 4L60-E, 4 Speed Trans, Transmission*; VIN: J, RWD, Auto Trans, Eng Code: LY5, 4L60-E, 4 Speed Trans, Transmission*
Per Vehicle: 1; Years: 2007-2008
Eickybobby5050
