juan84
Ordered a 3rd brake light for the yukon will update after it gets here!!
I have had mine on for about 2yrs been holding up just fine, it's a eagle eye so quality is acceptableOrdered a 3rd brake light for the yukon will update after it gets here!!![]()
Good to know thanks !!I have had mine on for about 2yrs been holding up just fine, it's a eagle eye so quality is acceptable
Lower. No question about it.Fighting that fight. Lower or not to lower. That is the question.
Looks good Britt, sounds like you got a plan for it.
Take a look around the site and you’ll see an entire section dedicated to ‘15 up... many ideas in there. Good luck.
The actual drain is that single hole in the left corner and gets clogged easily. That oval in the center is normally plugged with a rubber body plug. I removed all of the plugs in mine. The rear doors on my XL has two of those plugged oval holes, like on the front doors.
I'm waiting for Kenwood to release there 10" modular radio, should be anytime nowI bit the bullet and finally bought a radio to get rid of the stupid factory one that switches to auxiliary every 20 seconds... thanks for the recommendation @1BADI5 ...
Yup I looked and there’s definitely no springs.Someone stole your springs Rocket....
Lisle part number?Changed put my AC belt today. With that little tool from Lisle it was easy as pie.
