Thanks for looking out
No problem. I saw it when I was looking for an intake to replace the ugly stock one on my Silvy. But I don’t need anything near that one. 102 mm is good for what, 800 HP? I know the stock is good for 450-500. I just want a clean looking intake, I’ll probably get one of the welded aluminum ones idk.
I got the new manifold for my air system today and got to lay the Silverado out for the first time since I repainted the frame and links. Shame I have to put the bed back on eventually.
BG1988
cleaned up the electrical connections really good
found the problem Lots and lots of dirt
it was causing a bad connection on the positive cable right on the terminal
Charging voltage went from 14.2 High ripple.(it was all over the place )
to 14.8-14.9 volts stable when charging.
14.4 when charged state.
PPV12HOE
NC
I’m thinking a nice bed, maybe wood slats like the old school ones or just done with bed liner, on struts so it lifts up.
You could probably get a bed made up with a plexiglas floor... would be a b*@ch to keep clean for shows though...
HeavyHoe03
