Where can I buy the sunroof motor / actuator?
Matthew Jeschke
Sahuarita, Arizona
My sunroof was all busted up and missing parts. It's been RTV'ed shut but I'm determined to fix it now. So I bought an another assembly from the junkyard. I've tore it all down cleaned, greased, and tested the new setup. Turns out the new sunroof setup has a faulty motor just like my old setup. The gears are cracked on them both.
I see the motor assembly is AC Delco Part# 15163056 Unfortunately, that part says it's discontinued though. Certainly GM would have a replacement part or updated motor assembly as I'm guessing this is quite common.
Anybody know where I can get a new motor assembly? Or better yet a replacement gear set? I'm going to try to glue the gears back together. We'll see what happens. My truck is a 2001 Tahoe Z71 5.3L etc etc etc.
Multnomah Falls
Military
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
gm#15163056 part has been discontinued $430.68
can find part used off of another vehicle, looks like years are from 00-05.
I gave the search for this part a shot, as well, and I came up empty-handed. As recommended, you may need to find another motor assembly at a junk yard and piece the two assemblies together to create one complete working assembly.
RanchoTexas
