I fixed my cracks with JB Weld black plastic epoxy. You're supposed to mix the two parts 50/50, but I added an extra dab of one pf the two parts, I forget which. But, it cured to almost exactly the same color as the dash. I know yours is tan but I wanted to mention that for anyone with a black dash. Aside from color, the epoxy itself works wonders. If it were me, I'd cut a popsicle stick in half, apply epoxy to one side of each half and press them to the underside of the dash, spanning the crack like stitches. Might need to stuff a rag or newspaper underneath to lift and support it slightly if that closes the crack a little more. Let the eopxy cure over night, then reinstall the speaker with dense plastic foam glued to the magnet to support it. I'd have the foam thick enough so that it squishes just a tiny amount so that there's a slight bit of upward pressure. It'll settle over time and the upward pressure would essentially "zero out" so there'd be practically no force, up or down, on the center of the dash. It'd be supported, but not rigid.
That's a great idea I should have a small clamp that I could put on it overnight while it cures.
Sam Harris
Been eyeballing my cracked dash bouncing around for sooo long. The constant rattling is driving me crazy.
So I decided to investigate further and see if I can come up with some sort of support and why it is cracking. Of course the endless posts around the net and here on the TYF have that detailed to a "T".
I used a plastic panel tool and very carefully popped the 4 tabs on the center speaker cover to reveal the culprit of the 2 center speaker cracks.
1. Zero support in the center of the dash where it meets the front split.
2. Heavy ass Bose center speaker held in place by 2 screws.
3. Zero support on/around/under the Bose speaker.
The speaker is only held in in place with 2 x 7mm screw into the thread inserts. Very thin tabs to stabilize the speaker and dash in the center with no support.
So moving forward now that we have some details.
I am not interested in removing/replacing the dash at this point.
I've thought about some hot glue or quick epoxy around the tabs to secure them from completely separating from the dash.
Any thoughts about the extended cracks out from the cracked tabs where the screws go in place?
I thought about some hot glue/epoxy and a small bit of plastic under the existing cracks to keep them from opening up or spreading (unlikely to stop that from happening). Maybe some double sided foam gasket to keep the the gap between the 2 dash pieces from bouncing around so much.
I played the stereo without the center speaker and although not perfect, not even sure if the wife would notice. That would take the stress off the dash or test fit a piece of foam or something soft to absorb the bump under the magnet to fill in that gap behind the head unit and support the bottom of the speaker and dash.
Just figuring since I have that opening to work with a bit, to shore up the areas a bit. Not rigid, but flexible or shock absorbing for the dash.
Open to thoughts and input as I am spitballing here. Thx guys.
Speaker attached and cracks spidering out.
Speaker removed and can see the cracks.
You can see the cracks originating from the screw holes from the center speaker. Where those threaded insert tabs are x 2 the plastic has cracked where the tab is so the only thing holding it in place is the insert.
I can access that front left crack perhaps to glue and seal it together again, since both sides of the crack have already terminated. May not prevent a new crack originating from another but could at least join that crack back together.
The bottom crack maybe could stop it from advancing.
Just leaving the speaker out would relieve the stress of the center of the dash or as mentioned above something soft to take the weight of the magnet from hanging directly down.
Close ups inside the void. Looking forward.
Looking top down.
Man that’s bs..
Fosscore
I concur and thanks for the "stitches" vision. Kind of the idea I was thinking about since I can access it through the speaker hole.
Anybody done anything with the cracks over by the passenger airbag or just not looked over that direction? lol
Sam Harris
This
I plastic welded my broken dash using hot staples that I melted into the plastic from underneath ( no center speaker to blame it on btw) and used 1/8” metal rods with epoxy spanning the cracked areas, reinstalled it and put everything back together. A week later a new crack appeared. I ended up replacing the dash with the supposed redesigned one and added my own reinforcing as well. My thoughts are that the design as well as the plastic is defective and once cracking starts it’s pretty much done, it will continue. The plastic on mine was pretty damn brittle.
Fosscore
Man that’s bs..
Yes it is man. Well chronicled with the NNBS. No doubt the NBS was IMHO far superior with some of these weak points...e.g. interior and exterior door handles, dash cracks, A/C buttons paint, etc...just a few things that even on my low mileage, late model NNBS have had happen.
Something about the NBS....:)
I remember you doing this Mark. I know...likley a Band Aid but maybe a good treatment for now since not ready to replace the whole damn dash. ;)
you could apply the same thing over in the airbag area, you would have to pull the passenger side airbag to get in there to clamp it
Fosscore
you could apply the same thing over in the airbag area the cover comes off just like the speaker grill only not as easy just use a plastic trim tool I took mine off to get to the passenger side hvac actuator, might have to move the airbag to get a clamp on it I don't remember how much space there was in there with the airbag in place.
Do you by chance remember where the clips were located? 4 clips in the corners or maybe 6 clips? Yeah I gingerly pried off the speaker cover as it is pretty much paper thin.
about 2minutes in you can see where the clips go, looking at this again I think you will have to pretty much do what I did I think the cover is attached to the airbag.
lowh07
Needs a bath but I like this pic
lowh07
This is one of VERY few vehicles I’ve seen with black wheels that I actually like. Good job with those. [emoji106][emoji631]
thanks! They’re actually kind of a dark bronze but essentially black at the moment since they’re dirty. I’ve been thinking about switching it up.... maybe these in a 24.
I had some 24” slides a few years ago and kinda hated everything about them except the looks. In my opinion a 24 with a lip is the best look. Power loss to the wheels... ride quality... braking... I did however run a 305/35 which was about an inch taller than stock so I know that was a factor. I’m not big on the chrome lip but these would look amazing. Maybe white lip with black center..? or all brushed. Kinda want to get away from the black
I did the same over there as I did over my instrument panel:
Raised up each side of the separated pieces to spread the gap wider
Applied epoxy to the edges
Let the halves relax to firmly bite the epoxy
Used a wooden coffee stirrer to apply more epoxy to the underside
Used my finger to smear the epoxy on the surface to clean up excess and blend the epoxy into the surface to help mold over and hide the crack
Set steel blocks (centers of cut leaf springs) on it to weigh down the top so that it was a flat and even surface and let it cure
BTW, I grab a handful of the wooden coffee stirrers from the local bourgeois grocery store to use as free epoxy mixer/applicator sticks.
Pics of dash fix in this post: https://www.tahoeyukonforum.com/threads/growing-up-doesnt-have-to-suck.93510/page-10#post-1264681
lowh07
Tire to fender gap is a solid win!! And those ubars look nice.
thanks, actually gonna go with retrofitted stock housings next. One of the ubars started to go out after a few years so I unplugged them. The output is a little wonky too
Agreed. I'm trying to get that same stance. Fighting everything- drop parts not actually dropping as advertised, tires rubbing ******* the inner fenders...
I had some 24” slides a few years ago and kinda hated everything about them except the looks. In my opinion a 24 with a lip is the best look. Power loss to the wheels... ride quality... braking... I did however run a 305/35 which was about an inch taller than stock so I know that was a factor. I’m not big on the chrome lip but these would look amazing. Maybe white lip with black center..? or all brushed. Kinda want to get away from the black View attachment 240327
I can haz old 22s?
lowh07
mine rub sometimes but it hasn’t caused any issues so I don’t care anymore. Used to bug me a lot. Took me a few attempts to be happy with the height but now I’m thinking bags
I don't recall if I asked when I last inquired about your drop, sorry if I did but I've processed a lot of info since then, but what's your tire size?
Drewphil
