Black Betty 2018 Z71 Silverado....build
managed to get the power fold turn signal mirrors installed without to much trouble, wind blew over one of my door panels and scuffed it a hair but nothing unbearable :doh2:
Dammit! That would be how it'd go- you take all the precautions to not break anything when removing the panel then something like that happens.
I should have put in the back of the truck but I leaned it against the yukon instead and sure enough the wind kicked up out of no where.
Universe be like:
Just saw those tail lights for sale over at silveradosierra.com for $375, new in the box. Go figure huh.
weird those look clear, I only saw the red lens and smoked ones for sale, I like the red ones anyway
I need the dam power fold switch for the mirrors, apparently it's been out of stock since the strike
got all my Maestro adapters I need to pick some speakers, front doors have 6x9's, rear doors have 6.5, i've never really heard a decent 6x9 other than old school 2-ways so might just adapt the front doors to 6.5 also and run 2 sets of components, put subs under the rear seat, amps behind the rear seat, that leaves the dash speakers and a deck, I might wait a couple months on the deck both pioneer and kenwood will have there new ones out by spring or should anyway.
Look for wireless CarPlay if you use an iPhone.
ya I have a wireless deck in the yukon, I'm just waiting for the new decks to be released they showed them at ces last month, this truck has wired android auto/carplay but I want wireless, Alpine makes a nice 9" or 10" that will slap right in but it's not wireless
Hit a speed bump kind of hard today, it bottomed out and bam abs light and service traction/trailer system
I figured maybe I busted the trailer brake module, but no the idiots that did the drop before I owned it ran the right rear abs harness right between the axle and frame so if you bottom out it pinches the cable I found it in the dark with my flashlight and then scanned it and sure enough....
thought about repairing it but new oem ones are only $20 online, so i'll just get one from the dealer tomorrow
Nothing better than an easy fix except a cheap AND easy fix!
right? I was like crap the things probably $80-100, so I was surprised to see it for $17 from gmparts direct list $21, my local dealer gives me a discount so it should be the same price.
I'm just glad it wasn't one of the ones that goes inside the axle behind the bearing, I guess technically it is but the sensor just bolts on
That’s the reluctor. They almost never go out unless someone narrows your rear end and has non ABS axles built. I know that firsthand.
so what is the work around for no rear sensors? split the signal from the front?
The work around, after I replaced the reluctors and figured out they still weren’t gripping the axles, was to call Moser and order the right axles. So not a cheap OR easy fix.
New Interstate AGM $175 from Costco, kind of a pia, you have to disconnect a bunch of crap and move the reservoir.
only welded with it a couple times during the process :shocked: lol
had to re-calibrate the compass and reset the tpms and set the radio preset's the clock autoset.
thinking about getting one of these spoilers I have seen a couple around they look pretty sick, looks like it will run me about $450 shipped, it's fiberglass and then it has to be painted
wjburken
Eastern Iowa
If you’re going to leave it dropped, I say go for it. Not so sure it would look right if you go back to stock height or lift it.
On the NNBS they came with those stock. I have debated on putting one on mine since I bought it. It’s another thing the painter must have lost.
wjburken
Eastern Iowa
I think the piece on the truck that Wes posted looks like it is a little more pronounced than the stock one.
I thought I got the wrong tailgate cap on my 2007 when I bought it used until I discovered that they had two different stick tailgate caps. One was simply a round top cap and the other was the airfoil shaped cap. I kept looking for an airfoil style one but ended up trading the truck in before I found one at a price I would pay.
Jumpshot12
