Giggity Giggity !!!
Can't wait... but I guess I will.
So far, it seems to be operating how I've read how the stock system operates. My stock shock bags were blown and compressor roached when I bought my Tahoe so I've never personally experienced how it's supposed to work.
The bags fit firmly in place with no room for up or down movement, so any air pressure added to them won't be "wasted". This is ideal since they operate at a fraction of the pressure that the stock sleeves did and they don't "grow" as much. They need to be able to lift the rear to it's normal height with as little input from the compressor as possible, so any wasted travel is an issue. These fitting so well inside the TJ coils is yet another star aligning.
I unclipped the connector from the end of the stock air line and slid it back a few inches which left me with a bulb flared end. I pushed it into the Air Lift air line and it seems to be holding fine. I planned on backfilling the hose with epoxy to make the connection permanent and to ensure a seal, but that may not be necessary, at least not while I'm testing. I shoved it in further after this pic.
I need the system to think that the current, lowered height is the appropriate ride height. Otherwise, it'd think I had so much weight that it was sagging 4" and it'd try to air it up that 4". The Air Lift bags would explode long before it ever reached that height. To accomplish this, I shortened the sensor links to align the marks I made when it was at stock height. I removed the links, positioned the sensor arm to align the marks, then measured for the link length. I made the links out of a 6" piece of stainless 10-24 all thread rod. Just pulled the ends off the original link bars and threaded the stainless rod into them.
Before:
After:
I plugged in the fuse for the ALC compressor and turned the key on. After about 5-10 seconds, the exhaust valve clicked (system test) then the compressor came on for about 5 seconds. The bags firmed up a little and the rear lifted about 1/2". As far as I know, this is how the stock system works. I may shorten the links a hair cuz I really like the full 4" drop.
Bag snugly in place inside the TJ coil:
On the test drive, I might have detected a slight bit firmer ride. It was too minimal to know for sure. So far, I'm guessing I could call this is a "win". I need to test it loaded, so I'll use my crawfish pot idea to squat the rear about an inch, turn the key on to see if it lifts back to the same point, add more water to drop it another inch, etc.
kbuskill
NE. FL.
I unclipped the connector from the end of the stock air line and slid it back a few inches, which left me with a bulb flared end. I pushed it into the Air Lift air line and it seems to be holding fine. I planned on backfilling the hose with epoxy to make the connection permanent and to ensure a seal, but that may not be necessary, at least not while I'm testing. I shoved it in further after this pic.
I need the system think that the current, lowered height is the appropriate ride height. Otherwise, it'd think I had so much weight that it was sagging 4" and it'd try to air it up. The Air Lift bags would explode long before it ever reached that height. To accomplish this, I shortened the sensor links to align the marks I made when it was at stock height. I removed the links, positioned the sensor arm to align the marks, then measured for the link length. I made the links out of a 6" piece of stainless 10-24 all thread rod. Just pulled the ends off the original link bars and threaded the stainless rod into them.
Before:
After:
The next test, where you add extra weight, is really what I'm interested in.
I would be super interested to know what kind of pressure is in the bags currently and then again when its loaded down.
Since you are so thorough in your experimentation, I know you will put a gauge inline and report your findings... ;)
Great job so far.
Great job so far.
As you can tell by the quick and simple connections I made to the factory air line, I was pressed for time. I really do want/need to monitor the pressures, even if just during the tests. I have some Ts and Schrader valves and plenty of air line left from an install kit. I think I could quickly splice that into the connection between the factory and Air Lift lines. I'd just measure the pressure with a regular tire pressure gauge. Besides, it'd be really convenient to have a way to drain the bags other than pulling the lines apart while I'm sorting out my ride height with the bags pressurized. I'm really missing that .5-.75" drop I lose when they air up.
Does anyone know if it controls and adjusts the air in each side individually? I'm sure the factory wouldn't have both sides connected, as in T'ed at the compressor. This would be dangerous if loaded and taking a sweeping turn. If not controlled individually, maybe at least each side is isolated by check valves? I'll inspect my original compressor to see of I can figure it out, but wanted to see if anyone reading this knew.
kbuskill
NE. FL.
It is indeed T'ed at the compressor. No check valves, no isolation.
Use your Tech-2...
If I weren't blowing so much money on 5.3 AFM delete/refresh parts and buying coils and shocks I didn't need, I'd be able to get one. :facepalm:
I didn't know these things even had a pressure transducer. I thought it just ran strictly off of reference from the height sensors. Or is the pressure used for other functions?
I believe it's part of the compressor. Tom, Wes and Roger have talked about it before. I've got the dumb suspension, no compressor or height sensors.
@gooffeyguy @Doubeleive @avalonandl
The bcm can read the air pressure just not sure what it does with it, I see mine typically keeps 30-40lbs in the bladder it doesn't stay on any particular set number, when my last pump took a dump it was giving all kinds of weird numbers anywhere from 12lbs to 150lbs turned out it was leaking thru the internal valve.
kbuskill
NE. FL.
Interesting... I didn't know the BCM could see the pressure... but I don't have a Tech2 either, unfortunately :(
St. Louis
I want one, real bad... it's just the Burb has been running so good I haven't had a "need" for one yet... which is a good thing, I guess... lol
Running good or not, you will find something to mess around with if you had a Tech2!
My Denali runs fine, no codes, lights, issues, but going through the menus and seeing what it can do and what readings it can take is just, well, fun.... lol
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
kbuskill
NE. FL.
2001 Yukon SLT
I agree... it will happen eventually.
All the more reason why I should monitor the pressure in the bags. I believe they're spec'ed to 35 psi max.
be careful then, you might want to build a 35 psi relief valve of some sort
Word.
I just got back from getting dinner. I measured from ground to fender and it was 1/8" lower than where it was when I parked it Sunday night. I started it and put my tape measure to it. The compressor kicked on and it rose ~1/16". On the drive to the pizza place, it felt like it did when I drove it last. When I got back in it at the pizza place and started it, the compressor came on for about five seconds and I even felt the vibes in the seat. The ride home was a little more firm, not uncomfortable by any means. It felt more balanced with how the front rides. I did the hard slalom motions with the steering wheel and it was noticeably more controlled- less wag and quicker, almost immediate recovery and settling. When I got home and parked, I measured it again and found it was now 1/2" higher than when I started. Where I parked at the pizza place, it was an incline with a shallow dip running widthwise, like the Tahoe was parked over a ditch with the front wheels on one side and the rear over the other. I'm wondering if this loaded/squatted the rear a little more and the compressor put more air into it to pick it up. The extra air would've firmed up the ride which would make it feel more like the front as well as make it more stable against swaying. I liked the feel and handling, just not the lifted height.
So now I have to (1) Find out how much pressure it put in the bags to accomplish this firmness. (2) Lower it an additional 1" - 1.25". (3) Mark the sensors and adjust the links so that it airs up to this same sensor position.
This would give me my 4" net drop AND the desired spring rate (the slightly firmer one I had on the ride home) with the bags inflated to what the ALC system detects as "normal". Everything hinges on the amount of pressure being used...
Word.
Just remember the more weight you throw on the back the more it will try to inflate to keep the same height
BadDaddy2003
