A little love
1badc4
Well since motor transplant and Suburban to Tahoe transformation I had a chance to do some maintenance love. Changed transmission filter change, oil change with some mobile 1 hm and AC Delco filter. Also changed front and rear differential fluids. Only really had bad fluids in front diff. Was gray, obviously water in it at one point.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I would not discount the possibility of metal in the front diff old fluid turning it grey. Bearing debris or worse yet ground up gear debris. I would drive for a bit and recheck the fluid and listen close for noise while driving. I too recently did ALL the fluids on mine. Good luck.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I would not discount the possibility of metal in the front diff old fluid turning it grey. Bearing debris or worse yet ground up gear debris. I would drive for a bit and recheck the fluid and listen close for noise while driving. I too recently did AL the fluids on mine. Good luck.
I still need to do my front diff. I got everything rounded up for the project. Just need to order a fluid pump.
1badc4
1badc4
Hopefully not that. Magnet had small amount of slurry not too bad for 160k. It works well. Probably never even use 4wd.
briannorris
