HiHoeSilver
Away!
Chicago
Oil change with Shell Rotella Gas Truck 5w30 and NAPA 1522 filter. 105,000 on the clock. Checked other fluids and topped off the WW fluid.
EDIT: took a sample for Blackstone, once the mailer arrives.
First rotella change? Or was the sample you sent Rotella as well?
Super Moderator
Elev 5,280
First Rotella change, and this will be my first sample. I ordered the mailer the other day and it should be here in a week or so. The oil I drained is syn blend, unknown brand, done by a local shop while I had some other work done about 5K miles ago. Had a NAPA Gold filter on it, they do good work. But I wanted to get a baseline for future analyses.
Sam Harris
Turned the stock keys 2 more turns passenger side, and 3 more driver side. Now between 36.5-37” from ground to wheel well lip on all 4 corners. Replaced jounce stops with new ones, but the energy suspension spacers I bought are too tall, so returning those for 1/4” spacers. Replaced just pads on the front brakes, since I’ll be doing the NNBS brake upgrade after I wear out my tires. Added BG ATC Plus to the transmission, hoping to get enough out of it while I save for my swap.. Alignment tomorrow.. dc3afcb06e8bda8768ad09b1d6b87d2b.jpg9b7fedea2024051cd3d066a073931b0a.jpg
griffey_mojo
