Sooooooo, I bought a PPV ...
A123
The shocks won't change that. If you don't mind the harsh stock ride, I'd say go for it. I'd recommend a more progressive rate spring up front though.
No, my question is can I keep it at PPV height with these shocks?
I dont wanna go lower than PPV but definitely need a smoother ride...
RichardCranium
RichardCranium
Mebane, North Carolina
PPV height is only 1" lower than stock. If you have the 265/60 tires on there still, they are low profile and make the truck an additional 1" lower (2" all together). It doesn't matter what shocks you put on it, if you didn't change the springs......you aren't going to change the ride height. But in the same aspect, if you didn't change the springs and the tires, you are going to have the same ****** ride.
1BADI5
DMV
So I wanted to retain the OEM PPV front springs and shocks, so I'm dropping the front with the BellTech 2" drop spindles. Out back I'm using 3" springs, so effectively I'm doing a 2/2 drop on OEM sized tires.
Did you get the Spohn panhard bar?
RichardCranium
RichardCranium
I didn't, the difference in axle placement doesn't bother me enough to.
A123
So did u replace ur Springs? If yes, with what?
BTW, I put on 265/70/17 on mine
RichardCranium
RichardCranium
Great choice on the tires, they make a HUGE difference by themselves.
The 752SP kit retains the front springs but has new front struts, rear shocks, and rear springs. I might end up changing the front springs to a progressive rate, actually.
A123
So, if I buy this kit, I can keep it at stock PPV height? (I dont want it lower than PPV height)..
Also, any good brand I can buy only front springs that will improve ride quality?
RichardCranium
RichardCranium
This kit should put you 1" lower than PPV height. You can buy a progressive rate front spring, since it will likely be marketed from a 'normal' Tahoe, look for a 1" drop with the aftermarket spring to retain PPV height.
RichardCranium
RichardCranium
Have a link?
Got it added to the first post for easier navigation, save some folks PM'ing me most likely. :)
Damn I like that black grill
I am 100% happy with that purchase!
I wish I knew how to do that. Comes in handy sometimes.
I've been on the bulletin boards since around 2000, so I have lots of BB code stuck in my head. o_O
Super easy though!
[ url = http://whateverthewholelinkis ] Type what you want the clickable link to be here [ /url ]
Just remove the spaces.
Super easy though!
Thx. Gonna try it later.
I REALLY LIKE your train horn lol. I have one but I can't figure out how to wire it up using a relay.
scottd
