Upper control arm rubbing BAD w/ RC & CCM
N
  • N
    Votes: 0 0.0%
  • N
    Votes: 0 0.0%
  • Total voters
Mighty Hd
Florida
Hoping that the e can give me some advice here
13 Tahoe z71 4wd
2.5” CCM front leveling kit
RC 19401 upper control arms
Goodyear Duratrac 285-65r18
Factory z71 wheels
I noticedd this weekend the inside sidewalks of my front tires are getting destroyed. Apparently the UCA is rubbing like hell when I turn left or right. It starts at About 3/4 to full lock when turning.
I didn’t see anything on the installation requirements or notes about specific backspacing, or anything other than a 2.5-3.5} and 7” lift only working with these UCA
I can’t be the only one with this problem ....
If it keeps up, i will end up blowing a tire. Suggestions?
13 Tahoe z71 4wd
Factory z71 wheels
Did you contact the mfr of the control arms? You should not have to add spacers to a stock wheel but if they’re no help you probably have no choice.
M
Mighty Hd
Florida
I did contact rough country. They suggested 1/4” spacers.
So I purchased a set of 1/4” and a set of 2”
the 1/4” spacers didn’t help at all. The 2” RC spacers worked but I am going to have to do some heavy trimming for it to fit.
I returned all the RC spacers - they are lugcentric and felt cheap
I ordered a set of 2” BORA SPACERS.
the only other alternative is remove the RC upper control arms and run factory delco ARMS. the 2.5” CCM leveling kit puts them at a horrible angle and the Tahoe rides like shit.
The cheapest option at this time was 4 spacers. I’ll swap the wheels out in a few years when the tires are due to be replaced.
There are options between 1/4” and 2” spacers, why not go with something in between and maybe you won’t have to trim so much?
M
Mighty Hd
Florida
With the 2" spacers turned at full lock, i had about 1/2" clearance between the UCA and the sidewall.
Rough country is blaming the CCM 2.1 lift and not their upper control arms.
I didn't have this issue with the factory UCA, as soon as I switched to the RC, the rubbing started.
M
Mighty Hd
Florida
Ordered a set of bora spacers
nowi just need to find a set of midnight edition wheels.
M
Mighty Hd
Florida
@Mighty Hd Hey man how do you like the 2.5 CCM lift and the RC control arm combo? I am thinking of doing the same thing in the future.
I'm pretty pleased with it so far. I only did the front 2.5 -- the front sits about 1/2-1" higher than the rear and does not have the *** sag. No issues towing moderate loads.
I'm iffy on the control arms. It most certainly improved the ride quality, however the tires rubbed super bad at 3/4 - full lock. That required an additional $300+ for 2" bora wheel spacers as I'm not ready for aftermarket wheels just yet.
The 2" wheel spacers then required cutting the lower front bumper, zip-tying back the wheel well liner and a norcal mod. Once that was completed, no more issues.
Dustin Jackson
@Mighty Hd Thanks for the response, I already have 1.5 or 1.75 inch spacers on my factory 20 inch wheels so hopefully that is enough.
26AT4
