wjburken
Eastern Iowa
Why? I want one of those for mine. Sick of using a blanket.
I just don’t like how it looks, I guess, and where it sits height wise.
If the 3rd row seats are up, it sits right behind them in the rear mounting point which is fine but there isn’t much room to put anything very tall under it. To put it in the forward mounting position, the 3rd row seats need to be down flat or removed and there is a gap between the 2nd row seats and the cover.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
How much of a gap? That is the Suburban right? I don't run the 3rd row seats. That area is for my boat and fishing gear and cooler. My mount looks pretty close to the 2nd row seat backs.
Also, do you think it affects the rear heat efficiency when it is deployed?
wjburken
Eastern Iowa
Yes, I have the XL/Suburban wheel base. The gap is about the thickness of the 3rd row seats folded up so 6-8”. If the mount was about 1/2” further back, it would fit with them in the vertical folded position. Can’t speak to the Tahoe mounting points.
89Suburban
SE PA
Ahh I see. :)
Oh yeah, tinted factory with another layer of 5% static film. ;)
same as I have on all the back windows, you can't see nothing back there, I have some light tint on the front also so unless you stick your head up against the glass you cant really see if there even anyone sitting in the drivers seat from most angles.
89Suburban
SE PA
Yah! Just doing the 3 back windows super dark seems to have a huge effect on the whole vehicle overall. :) I live next to King of Prussia Mall and Norristown, lots of eyeball to the glass ******* criminals 'round here. That's why I still use a blanket for extra insurance, out of sight out of mind. Onto the next car with none of the above, leave my shit alone...
Geoffsfas10
St. Louis
Alright...lets try this...I changed some settings with my Flickr account to keep these off my main photo stream but they SHOULD show up since Im direct linking them..let me know if it works
Reverse Lights... 7440 Peak LEDs..ignore the fact that one side got cut off by my garage door edge.
reverse lights by Geoff Anderson, on Flickr
XB fog lights.. I will take better pictures of these once I do my retrofit in the next few months and go get good beam shots, when its warmer and using a tripod.
From the outside
xb fogs side by Geoff Anderson, on Flickr
Looking back at the truck
xb fogs front by Geoff Anderson, on Flickr
From inside the truck
xb fogs from inside by Geoff Anderson, on Flickr
I might move them up a touch when I do the retrofit but for now they are filling in nicely with the low beams. I will be getting some H11 LED bulbs in tuesday so I might go retake some output shot then as well. Im doing the LEDs to hold me over til I get around to the retro
kbuskill
NE. FL.
From the outside
Which LED low beam did you order?
From the outside
Those look good. I just checked mine, they’re 450 lm each and look about the same as those. Profile are good lights though.
ASG-MikeS
