How are we supposed to know exactly what it is?
I wish. It's an empty melon packing shed a few of us use for winter storage.That your garage?
Where does it go? Do you have a p/n? Is it at the bcm, steering wheel upper, steering wheel lower, any more information?Its a connector that is need for the tahoes that didn't come with the heated steering wheel.
It’s at the bottom of the steering column then?It's not a gm part. My truck doesnt have the heated steering wheel option. So i purchased a new clock spring and the wheel. Theres 2 green connector plugs on the clockspring, 1 goes to wheel, the other goes to a connector in the truck. Everything plugs up from the clocksping to the wheel its minus the 2nd green connector plug. The 2nd green connector plug is supposed to plug into some harness that provides ground and power. My truck doesnt have it. So the picture i posted is basically a male connector that i can plug into the hanging green connector and then I can wire it to ground and power. Im just looking for an official name i can search for it on Amazon or some other website
No shit!That your garage?
How many volts does it need? (12). Why can’t you just ground it and find (or install) a 12 v lead.?It's not a gm part. My truck doesnt have the heated steering wheel option. So i purchased a new clock spring and the wheel. Theres 2 green connector plugs on the clockspring, 1 goes to wheel, the other goes to a connector in the truck. Everything plugs up from the clocksping to the wheel its minus the 2nd green connector plug. The 2nd green connector plug is supposed to plug into some harness that provides ground and power. My truck doesnt have it. So the picture i posted is basically a male connector that i can plug into the hanging green connector and then I can wire it to ground and power. Im just looking for an official name i can search for it on Amazon or some other website
there may be a connector taped up to another harness down below the steering column I was watching a video on how to add one on my 18 Silverado and there was a connector it was just taped up to another harness.Not sure how many it needs. Im trying to do a clean install just in case i need to do a quick unconnect and connect
Maybe a wrecking yard? I’m thinking that might be hard to look up on a parts list.Not sure how many it needs. Im trying to do a clean install just in case i need to do a quick unconnect and connect
check the upfitter guide it may have the wiring diagram and voltage used, I wouldn't assume it's 12v, I tried that with a dimmer mirror once, it's a bummer to see money just vanish in front of your eye's lolI checked throughly. Nothing there
Have you checked to see if the air bags are blown? If I remember right, you’re interested in removing autoride? I love the auto leveling in mine after lowering, it keeps it from rubbing no matter how many people are in it even though I don’t have much clearance to the fenders.Used it to haul five passengers to the state fair last night. It drove nicely and the brakes were smooth and responsive. I could really feel the extra weight when changing lanes or turning at speed. All clear signs of blown shocks and dead ALC system. Just gives me more to look forward to after lowering it.
That sucks about the bolt. Maybe try a little heat? I’m sure you have a propane torch? Not sure if that’s enough to get it, but that’s what I’d try next.. if that doesn’t work, time for the sawzall.. those are the same Moogs I put on the Yukon. Happy with them. [emoji106]Put the Suburban back up on jack stands this morning. Removed the driver side sway bar bushing and gave it a good glob of grease. Went to remove the passengers side and one of the bolts will not budge. Rather it wants to round off. Tried a 6 point and 12 point deep socket and had a look at some vice grips. NOPE!! The sockets want to round off the head and the vice grip is not really going to work due to limited spacing.
Any further thoughts on getting that bolt to move without making the head into a marble??
As I was messing around on the passenger side, I think I found my clunking issue.
The passenger side stabilizer bar link bushing is gone! I guess I overlooked it in my hurry or maybe it finally just popped off.
Missing bushing under the sway bar.
Sway bar bushing bolt wanting to round off the head. 10mm.
Also removed and greased the rear sway bar bushings as well.
Here are the stabilizer bar link kits I am looking at. Moog Problem Solver which is what I put on the Tahoe.
Moog K700538 Stabilizer Bar Link Kit
https://www.amazon.com/Moog-K700538...2?keywords=K700538+moog&qid=1572793274&sr=8-2
Here is the Moog site link.
https://www.moogparts.com/find-my-p...rban 1500&values=2013~Chevrolet~Suburban 1500
Probably time for a drill bit and easy out on that bolt after a good soak with PB Blaster and maybe heat like Sam said. Those end links are a common failure due to a ****** design, they trap and hold water. The Problem Solver line is there because GM has a problem with some of their designs lol. Good choice.Put the Suburban back up on jack stands this morning. Removed the driver side sway bar bushing and gave it a good glob of grease. Went to remove the passengers side and one of the bolts will not budge. Rather it wants to round off. Tried a 6 point and 12 point deep socket and had a look at some vice grips. NOPE!! The sockets want to round off the head and the vice grip is not really going to work due to limited spacing.
https://www.moogparts.com/find-my-part/find-my-part-results.html?parttype=SUSPENSION&apptype=AUTOMOTIVE&options=2013~Chevrolet~Suburban 1500&values=2013~Chevrolet~Suburban 1500
