Kee Fuller
las vegas
anybody know where i can find this online?
Kee Fuller
las vegas
Where does it go? Do you have a p/n? Is it at the bcm, steering wheel upper, steering wheel lower, any more information?
It's not a gm part. My truck doesnt have the heated steering wheel option. So i purchased a new clock spring and the wheel. Theres 2 green connector plugs on the clockspring, 1 goes to wheel, the other goes to a connector in the truck. Everything plugs up from the clocksping to the wheel its minus the 2nd green connector plug. The 2nd green connector plug is supposed to plug into some harness that provides ground and power. My truck doesnt have it. So the picture i posted is basically a male connector that i can plug into the hanging green connector and then I can wire it to ground and power. Im just looking for an official name i can search for it on Amazon or some other website
It’s at the bottom of the steering column then?
Sam Harris
How many volts does it need? (12). Why can’t you just ground it and find (or install) a 12 v lead.?
Not sure how many it needs. Im trying to do a clean install just in case i need to do a quick unconnect and connect
there may be a connector taped up to another harness down below the steering column I was watching a video on how to add one on my 18 Silverado and there was a connector it was just taped up to another harness.
Used it to haul five passengers to the state fair last night. It drove nicely and the brakes were smooth and responsive. I could really feel the extra weight when changing lanes or turning at speed. All clear signs of blown shocks and dead ALC system. Just gives me more to look forward to after lowering it.
Have you checked to see if the air bags are blown? If I remember right, you’re interested in removing autoride? I love the auto leveling in mine after lowering, it keeps it from rubbing no matter how many people are in it even though I don’t have much clearance to the fenders.
Fosscore
Put the Suburban back up on jack stands this morning. Removed the driver side sway bar bushing and gave it a good glob of grease. Went to remove the passengers side and one of the bolts will not budge. Rather it wants to round off. Tried a 6 point and 12 point deep socket and had a look at some vice grips. NOPE!! The sockets want to round off the head and the vice grip is not really going to work due to limited spacing.
Any further thoughts on getting that bolt to move without making the head into a marble??
As I was messing around on the passenger side, I think I found my clunking issue.
The passenger side stabilizer bar link bushing is gone! I guess I overlooked it in my hurry or maybe it finally just popped off.
Missing bushing under the sway bar.
Sway bar bushing bolt wanting to round off the head. 10mm.
Also removed and greased the rear sway bar bushings as well.
Here are the stabilizer bar link kits I am looking at. Moog Problem Solver which is what I put on the Tahoe.
Moog K700538 Stabilizer Bar Link Kit
https://www.amazon.com/Moog-K700538...2?keywords=K700538+moog&qid=1572793274&sr=8-2
Here is the Moog site link.
https://www.moogparts.com/find-my-p...rban 1500&values=2013~Chevrolet~Suburban 1500
Sam Harris
That sucks about the bolt. Maybe try a little heat? I’m sure you have a propane torch? Not sure if that’s enough to get it, but that’s what I’d try next.. if that doesn’t work, time for the sawzall.. those are the same Moogs I put on the Yukon. Happy with them. [emoji106]
trailblazer
Oh crap you’re going to have to hammer on a 12-pt socket after heating the shit out of that bolt. I have a Port-A-Torch oxyacetylene kit that will get it cherry red but a long time with propane may work too. Find a 12-pt that is just a tad smaller.
https://www.moogparts.com/find-my-part/find-my-part-results.html?parttype=SUSPENSION&apptype=AUTOMOTIVE&options=2013~Chevrolet~Suburban 1500&values=2013~Chevrolet~Suburban 1500
Probably time for a drill bit and easy out on that bolt after a good soak with PB Blaster and maybe heat like Sam said. Those end links are a common failure due to a ****** design, they trap and hold water. The Problem Solver line is there because GM has a problem with some of their designs lol. Good choice.
Edit: you might want to look into some sway bar bushings with grease fittings like the poly ones at Energy Suspension so you never have to remove those bolts again.
wwiizz
