TPMS relearn tools..2014 SSV Tahoe
5strmtrp
Since I put the newer set of tires and wheels on my 2014 Tahoe SSV I’ve been getting the TPMS light and warning message on the truck.
I know that it needs to be set to the vehicle. Does anyone have a good suggestion on a relearn tool? I’ve been looking at Amazon and a few other sites but they have a ton of them out there. I also have my wife’s 07 Aura XR that gets winter tires on it as well those have the sensors in them as well just never worked.
note: the wheels came from a 2011 Tahoe and the wheels do have sensors in them. Same stock tire size.
Thanks
Paul
wjburken
Eastern Iowa
Thanks
Paul
This one seems to cover all the bases and covers a wide range of years for GM vehicles.
https://www.amazon.com/gp/product/B...L82JP&linkId=a64287f43df0e42e859d9ac458f93e6c
09Tahoe4Now
That’s the correct TPMS tool that will allow you to do the relearn in less than a minute.
Big Mama
Virginia
Just wondering what year GM removed the feature in the DIC where you didn’t need a tool? Or is it the TPMS that’s different?
I think it changed in 2011 on my 2012 you have to use the oem key fob to put into learn mode and then use a tpms tool as well, on my 2018 silverado you just select the tpms display then hold down the select button for about 5 seconds and it goes into learn mode (found that out by accident).
Ilikemtb999
Denver
Those cheap china relearn tools work well. Use it on my car and my Tahoe since filling/letting air out sucks.
5strmtrp
5strmtrp
Thanks all for the suggestions. Will go ahead and order one this weekend.
I see here that you have to use the key fob as well as the relearn tool?
Why can’t it be easy, yeesh.
Paul
Ihaveatahoetoo
