sonic_the_hedgeh
I did change all the drivetrain fluids last year as well, on top the rad was flushed. Added some supercooler additive and that helped lower Temps by about 15 degrees. It's a 2004 denali with 348,000 km's and running fine. I also just put the regular size all terrain tires on. Thanks guys.
Sent from my CLT-L04 using Tapatalk
sonic_the_hedgeh
Yes I think the stock thermostat is 195 sounds right. I work at a parts desk sounds right
@iamdub what rear coil spacer did you use?
Belltech calls it a "Spring distance kit". BT part number 35323.
https://www.amazon.com/Belltech-35323-Spring-Distance-Kit/dp/B00HWOKLUQ
And does anybody know if the Z71 rear coil does same thing as a 1” spacer?[/USER]
I thought the Z71 was 1.5" higher than the regular ones? Regardless, stock spring plus spacer or longer spring and no spacer will all provide lift. The different springs may alter the ride quality a little, but probably nothing significant or negative.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Not today but over the weekend. Powerstop brake kit for the front. :)
BG1988
Well got my ****** gas mileage problem figured out for me
no you have a second code P0430 is just a secondary code it means you have another code as well
IF your cats were bad you would have Stoner code P0420 or P0421 AND P0430 (it means the first code is True)
NOT NOT I REPEAT NOT P0430 (it means anything could be wrong with it )
with
47 Enable Conditions for a P0430
and your going to believe that your cats are dead ahaha don't come crying after you had gotten scammed...
this person might work for a smog shop but is clearly scamming you
when I got the P0069 Code It had the P0430 included
after replacement of the map sensor
and rest and 2,000 miles later no more codes...
also my mpg has restored to the normal 25mpg HYW and 22 city(my city lol)
BG1988
just cleaned out AutoZones stock of Mobil1
they had a Promo for 20$ for a 5qt plus 12$ rebate
Cleaned out all the local stock from all the autozones.. so now i have enough oil to start my own oil company..
(had someone else do them because i used all of mine all ready) ;)
wjburken
Eastern Iowa
P0430 is a secondary code? Please explain as this is new information to me.
Edit: Never mind, you completely cleared everything up with the additional verbiage that you added 10 minutes after I asked the question.
with
only 1 code and it hasn't returned, nor any other code, I have a habit of burning up cats apparently
AND what person? the only person involved here is me
BG1988
P0430
is not a cat code
only
P0420 bank1/p0421(bank2) = failure
wasting money when you have not fixed the actual cause of the failure such as leaking fuel injector vacuum leak etc.. under normal conditions the catalytic converter will last 150,000 to 300,000 miles
with
Ahem....
What Is the Cause of Code P0430?
  • Faulty oxygen sensor
  • Faulty air-fuel sensor
  • Worn or internally failing catalytic converter (Most Common)
  • A leak in the exhaust system
  • Misfire (the root cause of converter failure)
  • Rich or Lean air-fuel ratio (the root cause of converter failure)
  • Leaded Gasoline (the root cause of converter failure)
CKendrick
