YEP, SAME HERE LOLA 2” front 1” rear would be perfect for me so I quit banging my head on the damn lift gate.
Yep like a 5 dollar ******....Damn Houston getting hit again.
YEP, SAME HERE LOL
@iamdub what rear coil spacer did you use?
And does anybody know if the Z71 rear coil does same thing as a 1” spacer?[/USER]
I need to do that. Looks good. What did you use?
Very nice!
no you have a second code P0430 is just a secondary code it means you have another code as well
only 1 code and it hasn't returned, nor any other code, I have a habit of burning up cats apparentlyno you have a second code P0430 is just a secondary code it means you have another code as well
IF your cats were bad you would have Stoner code P0420 or P0421 AND P0430 (it means the first code is True)
NOT NOT I REPEAT NOT P0430 (it means anything could be wrong with it )
with
47 Enable Conditions for a P0430
and your going to believe that your cats are dead ahaha don't come crying after you had gotten scammed...
this person might work for a smog shop but is clearly scamming you
when I got the P0069 Code It had the P0430 included
after replacement of the map sensor
and rest and 2,000 miles later no more codes...
also my mpg has restored to the normal 25mpg HYW and 22 city(my city lol)
P0430only 1 code and it hasn't returned, nor any other code, I have a habit of burning up cats apparently
AND what person? the only person involved here is me
with
