The download from tdsweb says it completed but No love, at least not what I was expecting, trying a key relearn again, 1st try didn't work.if the security light goes out in 5 more minutes at least I'll be getting somewhere
What are you trying to fix?
St. Louis
My nano-ceramic tint cost $130 for front driver/passenger windows, $220 for the rear 5 windows, or $350 total for all windows.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Whenever I disconnect the battery then reconnect it, then it won't start, I have to disconnect the battery again, flip switch, press the brake etc, reconnect the battery then it will start, the problem appears to be the security module.
Now the stupid security light is on and won't go out after 10 minutes with the key in like it should be doing
HiHoeSilver
Away!
Chicago
I’ve been to three different shops asking if they had luck with just repairing the tabs and none of them said that they had good success rates with repairs.
Ummmm, because they want to bend you over on the rear glass for $700. You can nay-say it or just take the word of the guy getting your cash if you'd like... but there are multiple reports on this forum of long lasting successful repairs. @Rocket Man , @Sam Harris (both of which even conversed on some handling tips recently)...Jussayin.
New cluster lights work anyway
R3cord303
Posse In Effect
Oregon Valley
I only say that because one of the shops I went to- told me that he doesn’t even do glass anymore- but that 10+ years ago when he did do glass in his shop was when he had mixed results. I’ll try the goop that was mentioned but in the past it’s always seemed like I try the $10 fix to avoid the $100 fix- and end up spending $110.
veteran111
