Yep. Just did this on mine. Both sides and they’re set for winter.$700? That's crazy! Use Frostfighter.
Replaced the security antitheft module, doing the relearn with the tech2 on TDS web, hoping I don't brick this bish,find out in 10 minutes
The download from tdsweb says it completed but No love, at least not what I was expecting, trying a key relearn again, 1st try didn't work.if the security light goes out in 5 more minutes at least I'll be getting somewhereIt’s been 55 minutes, any update?
What are you trying to fix?The download from tdsweb says it completed but No love, at least not what I was expecting, trying a key relearn again, 1st try didn't work.if the security light goes out in 5 more minutes at least I'll be getting somewhere
Whenever I disconnect the battery then reconnect it, then it won't start, I have to disconnect the battery again, flip switch, press the brake etc, reconnect the battery then it will start, the problem appears to be the security module.What are you trying to fix?
Is there such thing as an immobilizer delete for these trucks?Trying a key relearn with the tech2 and tdsweb, ugh what a pain in the dick shouldn't have messed with it.
Is there such thing as a pain in the dick delete for these trucks?
I’ve been to three different shops asking if they had luck with just repairing the tabs and none of them said that they had good success rates with repairs.
thanks not 100% sure I like it yet or not, it's def differentOooh. Almost hypnotic! Looks great.
I only say that because one of the shops I went to- told me that he doesn’t even do glass anymore- but that 10+ years ago when he did do glass in his shop was when he had mixed results. I’ll try the goop that was mentioned but in the past it’s always seemed like I try the $10 fix to avoid the $100 fix- and end up spending $110.Ummmm, because they want to bend you over on the rear glass for $700. You can nay-say it or just take the word of the guy getting your cash if you'd like... but there are multiple reports on this forum of long lasting successful repairs. @Rocket Man , @Sam Harris (both of which even conversed on some handling tips recently)...Jussayin.
there's probably some way around it i'm sure, couldn't be that hard to run a wire to the starter and another to the fuel pump if worse came to worseIs there such thing as an immobilizer delete for these trucks?
