You want the TA 1807A Low Profile. It fits all GM 10 bolts and it won’t matter if you change to an Eaton carrier. Make sure it’s the low profile, the regular one won’t fit. Don’t forget a gasket.
http://www.taperformance.com/proddetail.asp?prod=TA_1807A
Edit: I didn’t buy their stud kit, I just took a sample of my bolts and bought stainless ones at Ace Hardware.
when you changed the control arm's was there any trick to it, like does the frame need to supported or the axle?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I had to ask cuz I wanna remove mine but not until I know how I wanna plug the holes. I was gonna reuse the screws, but now that I know about the shoulders...
My current plan of action is to use socket-head set screws with thread adhesive sealant and some plastic caps painted body color. I'd probably use a mild adhesive to secure the caps. I'd use a butyl-based adhesive cuz silicone can corrode bare metal.
Maybe something like this:
How about a hex head bolt with a cap that fits over it and snug to the roof? I ask this because when I disassembled this, 6 of the 10 screws threads were RUSTED BELOW the roof line. Which means water is getting in there, and THROUGH the tightened threads of the blind nut. I know a thread sealant would combat this capillary action, but I was also worried about sealing the actual protruding sides of the top flange of the blind nut AND where it meets the roof metal. The flanges of the blind nuts were all SLIGHTLY surface rusted. I wanted them totally weather sealed. The roof panel area meeting the blind nuts were painted and looked perfectly fine.
"silicone can corrode bare metal" - I never had this problem, been using it like this for for years. I think if you don't put it down too thick and it fully cures it should be fine?
Just a heads up for ALL who have these luggage racks. These are very easy to remove and reinstall. You will be shocked at the amount of grime and dirt built up under the nylon mounting pads on the roof's painted surface, and the underside of all the crossbars and rails. VERY nasty, and I wash my tuck religiously. It would not be a big deal and a fun tinkering project for some Saturday or Sunday afternoon to remove the rack, and thoroughly clean all those areas. Wire brush any rust off the bolts, maybe spray and wipe down with a protective *********, and and reinstall with thread sealant on the bolts.
They main reasons I removed this was I got sick of moving the bars every few months to wash tree sap from under the bars on the roof surface. And I never use them so I decided to come off for now. I can always re-install later. I just might now that I see that weird curve in the roof line now at the front mounting areas...
If you mean the flip-top caps that the bolt goes through the bottom half then the cap snaps over it, I decided against this style because I'd expect the plastic to warp, shrink, dry rot, etc. in the sunlight and heat and, eventually, the caps wouldn't stay snapped closed.
If you were talking about the caps that are basically a disc with a hex-shaped recess to fit over the bolt head, that would work as well but would need to be adhered somehow. They would also sit much higher off the roof than caps snapped into set screws that were flush with the roof line. Thread sealer, such as what is used on bolts that protrude into water jackets in engine blocks should be plenty sufficient as it is (obviously) heat- and water resistant. The flat caps I'd snap over the set screws would have a layer of adhesive sealant (windshield adhesive, etc.) applied to the underside to secure them as well as seal them from the outside. Windshield adhesive is designed to adhere and seal and not weather, so it's ideal. When I press the cap onto the set screw, the adhesive will squish out around the edges. I'd just wipe off the escess while it's still wet. The threaded insert will be completely encapsulated by plastic that's covered by body paint and UV-reflective clear coat as well as adhesive sealant designed for such a purpose. The flat caps would be maybe 2mm high rather than the hex bolt caps which would stand off the body the thickness of the bolt head plus the thickness of the plastic itself. The lower profile would be much cleaner.
The problem is more common with electronics that are sealed in boxes with regular silicone. The solder and copper are more prone to react with the fumes released by the silicone as it cures. Used in an open automotive environment, the gases can escape. Maybe the problem is inconsistencies when applying the silicone that create air pockets under the cured silicone "skin" leading to corrosion? Maybe you don't apply the silicone excessively thick and you lay a consistent enough bead that there aren't any voids created to encapsulate gases. All I know is I've seen window frames rotted out all around because a leaking window gasket was sealed with household silicone sealant. Though, there are other factors involved such as the alloys in the metal the car body was stamped from and the chemicals used in the production of the silicone itself, all of which may (and likely) have changed over time. I'd still rather play it safe and use purpose-made stuff. Common household silicone sealant isn't as stable in constant outdoor environments as automotive windshield adhesive.
If you turn a corner hard, real hard, the side of the tire can move over an inch and not break the bead with the tire. That's what I was referring to in my earlier post.
And that's with low-profile performance tires. I'd imagine the stock 55-series balloons to easily deflect 2 inches under hard cornering.
wjburken
Eastern Iowa
I’ve seen people use tree rivets with a little silicone or RTV to plug holes as well. They are low profile.
https://www.mcmaster.com/tree-rivets
I supported the frame with jack stands and then put a floor jack under the wheel to adjust that side of the axle up or down as needed. BTW I felt zero difference as far as vibrations or anything else with the poly bushings.
does that girdle drain plug have a magnet on it or is it magnetic? if not I may epoxy a small one on it
R3cord303
Posse In Effect
Oregon Valley
Forgot to post a picture at the time but the catch can for my 07 arrived. $25 on amazon doesnt seem too bad! Will install it once the new engine is in.
Excuse the Ford steering wheel- borrowing parents expidition while tahoe is down. Its getting new engine installed wednesday-friday next week.
on my old s10 i put poly on the front and rear sways and the LCAs. Litte bumps felt more harsh but big bumps felt more smooth. For sure made it feel better during spirited drives.
Mlstammerjr
